Drives: 2013 Panda ft86/FRS
Car won't crank without the oft plugged in
Just as the title reads, cr went down to be built/turboed, now that it's back together it isn't want to crank(rotate engine) without the oft plugged into the the port,
Flashed the ecm to the new map and back, and then again it does the same thing, I'm going to go over it all again but this one has got me
The Dictater
Drives: '13 Red Scion FRS
This might seem like a silly question but are you sure it cranks with the oft plugged into the obd port?
That makes no sense.
The oft or any flash device transfers tune to ecu then it takes no further part in engine operation. If your turbo its likely that the tune you flashed does not match the MAP sensor installed or the injectors installed. |
I got it sorted, it was something very dumb
| The Following User Says Thank You to 1quickchic For This Useful Post: | bcj (12-25-2018) |
Drives: 2017 BRZ
But you're not gonna tell us what dumb little thing it was?
-Phil's BIGGEST FAN BOI
Drives: 2014 Greddy Turbo BRZ
does a female EVER tell you what the problem is straight up? haha. we gotta SOLVE IT OURSELVES MAN.
2014 Subaru BRZ
Don't follow your dreams, follow my instagram www.instagram.com/soloside |
| The Following User Says Thank You to Soloside For This Useful Post: | tomm.brz (12-24-2018) |
#7 | |
| The Following 2 Users Say Thank You to Tcoat For This Useful Post: | bcj (12-25-2018), Ultramaroon (12-24-2018) |
it was a ground
| The Following User Says Thank You to 1quickchic For This Useful Post: | bcj (12-28-2018) |
| OFT Keep plugged in without killing battery? | Axion | Software Tuning | 19 | 06-06-2020 10:30 AM |
| connectors not plugged in?? | trexx0411 | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 08-03-2015 08:00 AM |
| Found A Connector Not Plugged In | bruizerrob | Scion FR-S / Toyota 86 GT86 General Forum | 14 | 08-03-2015 06:55 AM |
| Stock FRS radio harness there but not plugged in? | Roadstercycle | Electronics | Audio | NAV | Infotainment | 1 | 04-20-2014 04:33 AM |
| Are my accessory jacks plugged in? | dale.m | Electronics | Audio | NAV | Infotainment | 3 | 10-09-2012 12:14 AM |
