Old 01-18-2015, 01:02 PM   #1
Axion
Axion
Axion's Avatar
Drives: 2013 BRZ (Dark Grey Metallic)
OFT Keep plugged in without killing battery?
My OFT Tablet I leave plugged into my BRZ but it seems if I don't start it for 24-48 hours it will kill my entire battery.
Is there anyway to make it timeout after X amount of hours?
Axion is offline   Reply With Quote
Old 01-18-2015, 01:15 PM   #2
phrosty
Someone could make a small amount of money creating cables with an on/off switch.
2013 Whiteout 6AT FR-S | Perrin Inlet Tube + 2.75" CAI | OpenFlash Header | P&L Catback | 4.88 Final Drive | Dialed in OFT 2.0x Stage 2 E85 | 18x8 Enkei Raijin + 225/40 Michelin Pilot Super Sport | 17x7 Stock + 215/45 Michelin X-Ice Xi-2
phrosty is offline   Reply With Quote
Old 01-21-2015, 01:55 PM   #3
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
Wondering the same thing, its annoying to have to plug/unplug the OFT.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 06-04-2020, 09:50 AM   #4
Sam86
Drives: Toyota 86 GTS
Sorry for the bump, just wanted to know if leaving the OFT ecu cable plugged in still draws from your battery- just the cable, tablet is unplugged from it
Trying to narrow down possible causes for almost being unable to start my car today (took about 4-5 cranks) which I suspect is from the battery being close to drained- Granted I was in accessory mode with the radio/ heater/ lights on but regardless I was only in it for 10-15minutes before trying to leave and facing that issue which I doubt is normal.
So either my battery is due for replacing, or having the oft cable by itself is still drawing power and has dwindled away my battery over the past few weeks
Sam86 is offline   Reply With Quote
Old 06-04-2020, 02:26 PM   #5
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
You have 3 solutions. Use the adapter that has a power switch, unplug each time, get a battery big enough where it has a lot of excess power.
I went with an OBD2 adapter with a switch purchased from Jeff Bezos
Intent > Content
Old 06-05-2020, 02:42 AM   #6
Sam86
So you're saying the cable plugged in by itself (no OFT tablet connected to it) does infact still draw power?
Old 06-05-2020, 02:48 AM   #7
solidONE
solidONE's Avatar
Just get this: https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
It's self explanatory
You switch it off, it gets no power. So no power draw while off.
Intent > Content
Old 06-05-2020, 03:00 AM   #8
solidONE
solidONE's Avatar
In case you guys weren't familiar with who Mr. Bezos is.
Intent > Content
Old 06-05-2020, 07:54 AM   #9
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
No it doesn’t, I leave the cable plugged in over the weekend but undo the OFT from the cable. No drain.
The Following 2 Users Say Thank You to Yoshoobaroo For This Useful Post:
Sam86 (06-05-2020), solidONE (06-05-2020)
Old 06-05-2020, 12:34 PM   #10
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Why do you leave your OFT in all the time? Seems pretty pointless.
Old 06-05-2020, 02:30 PM   #11
Yoshoobaroo
TRACKBREAD
To watch temps and fuel trims.
Old 06-05-2020, 02:42 PM   #12
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Does the torque app not accomplish the same thing?
That is what I use for temps and AFR
Old 06-05-2020, 03:25 PM   #13
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
I understand doing that on occasion or when making a change, but all the time
Old 06-05-2020, 03:28 PM   #14
Yoshoobaroo
TRACKBREAD
I usually have it in the car for ~3 weeks after flashing something new, then I take it out if all is well
Torque can’t read IAM
Lumbar support for seats? My lower back is killing me Indestruct Cosmetic Modification (Interior/Exterior/Lighting) 65 05-18-2017 11:56 AM
DIY - Killing Drone - 1/4 or Branch Resonator BRZ.PTY DIY (Do-It-Yourself) Guides 9 01-08-2015 08:05 AM
I guess i'm killing people... Darryljr11 Scion FR-S / Toyota 86 GT86 General Forum 49 09-06-2013 12:54 PM
iPhone plugged in via USB not acknowledged after restart OnTheFence Electronics | Audio | NAV | Infotainment 5 08-20-2013 10:47 AM
Are my accessory jacks plugged in? dale.m Electronics | Audio | NAV | Infotainment 3 10-09-2012 12:14 AM
