Old 04-01-2015, 12:09 PM   #1
bruizerrob
Drives: 2013 Scion 10 series frs
Found A Connector Not Plugged In
While running a wire for my backup camera, I found a connection not snapped together in the driver's side footwell behind the kick panel. The wire I ran went to a connection with a black locking hinge on it, and just above it, there it was. Not together at all. I have never been behind this panel before and I am the 1st owner of the car. I don't know what that connection is for. I'd love to upload a photo but tapatalk keeps crashing every time I try. Anyone know what all systems pass through that connection?
Sent from my SAMSUNG-SM-N910A using Tapatalk
bruizerrob is offline   Reply With Quote
Old 04-01-2015, 01:06 PM   #2
Hard to tell but there are a few connectors that are not hooked up back there. Could be nav GPS antenna, mirror heaters or any other number of options that you don't have. Believe it or not it is cheaper to put these things in on the line and not use them than it is to custom build each individual car.
As long as everything works all is good.
Old 04-01-2015, 02:58 PM   #3
Probably not a NAV antenna, at least not on the FR-S. The NAV antenna comes with the GPS unit, and attaches via a magnet plate to the underside of the dash. I was very surprised when I installed it on mine but it seems to work well.
Old 04-01-2015, 03:03 PM   #4
Ya, just guessing at some possible parts. I found two danglers when I was looking up under there once but everything works so they are obviously left overs.
Dadhawk (04-01-2015)
Old 04-01-2015, 03:14 PM   #5
extrashaky
Drives: 2014 BRZ Limited
Is it a 4-pin connector with blue tape on the wire?
There are a lot of threads on this, but so far I don't think anybody has figured out exactly what that thing is for. People have speculated that it's for the alarm, interior lighting or door accessories. I suspect it's for the alarm keypad hidden in the glove box of the European BRZs, which we don't have in the North American models, which would explain why no NA folks have found it hooked up to anything yet.
I'm wondering if it has a hot lead, and if so whether that would be a good wire to tap into for extra accessory power. I'm not sure I want to try that, though, until someone can verify what it's for. I don't want to inadvertently enable the ejector seat.
The Following User Says Thank You to extrashaky For This Useful Post:
Tcoat (04-01-2015)
Old 04-01-2015, 03:17 PM   #6
Yes, ejection seats should only be activated advertently. There are times I would pay good money for that option!
gramicci101 (04-02-2015)
Old 04-01-2015, 04:34 PM   #7
mikeTee
Yup.
mikeTee's Avatar
Drives: MT Subaru BRZ '13
99% sure it's for the USDM fog light kit.
http://www.ft86club.com/forums/showthread.php?t=40153
mikeTee is offline   Reply With Quote
The Following User Says Thank You to mikeTee For This Useful Post:
Tcoat (04-01-2015)
Old 04-01-2015, 04:56 PM   #8
extrashaky
Oh, driver's side. I misread the OP and was looking at the black 4-pin connector on the passenger side.
Tcoat (04-01-2015)
Old 04-01-2015, 07:46 PM   #9
continuecrushing
continuecrushing's Avatar
Drives: 2013 Firestorm FRS
no "its for the turbo" comments yet lol?
Old 04-01-2015, 08:07 PM   #10
gramicci101
Off Topic
its for the turbo
edit: dammit!
Old 04-02-2015, 07:12 PM   #11
bruizerrob
the blue circled connector is the one that I used for the reverse signal to go back to the radio, the red circled connector is the one that was unplugged. call me crazy, but I think it had something to do with the audio system. it sounds way different now that i plugged it in. None of my settings changed in my radio, but it definitely sounds different.
Old 04-02-2015, 07:21 PM   #12
bruizerrob
Looking at page 47 in our wiring diagram, which can be found here http://www.ft86club.com/files/BRZwiringi.pdf it is plug HD2. doing a search on that pdf shows that it has audio amplifier signals traveling through there, so my suspicions may be correct. I have deeper bass now, and the audio doesnt sound like it is coming through a tin can. It may be worth checking your own connections if you have lousy stock audio.
Old 08-02-2015, 08:58 PM   #13
trexx0411
trexx0411's Avatar
Drives: 2015 Scion FRS
I found one not plugged into anything on the passenger side though. Not sure what it is.
trexx0411 is offline   Reply With Quote
Old 08-03-2015, 12:26 AM   #14
3nl
Drives: 2015 FR-S 6MT
They put it there just to mess with people on the forums. If you car hasn't caught on fire yet, you're definitely okay.
3nl is offline   Reply With Quote
The Following User Says Thank You to 3nl For This Useful Post:
Tcoat (08-03-2015)
OFT Keep plugged in without killing battery? Axion Software Tuning 19 06-06-2020 11:30 AM
Stock FRS radio harness there but not plugged in? Roadstercycle Electronics | Audio | NAV | Infotainment 1 04-20-2014 05:33 AM
iPhone plugged in via USB not acknowledged after restart OnTheFence Electronics | Audio | NAV | Infotainment 5 08-20-2013 11:47 AM
I found an extra connector under passenger side dash. boredom.is.me Electronics | Audio | NAV | Infotainment 29 01-05-2013 10:43 PM
Are my accessory jacks plugged in? dale.m Electronics | Audio | NAV | Infotainment 3 10-09-2012 01:14 AM
