Drives: 2015 BRZ Series.Blue
P0365 Fault Code
I keep getting a P0365 code. Camshaft Position Sensor "B" Circuit Location Bank 1. From what I've been able to gather is that this particular sensor is on the Passenger side and is the sensor on the Intake, correct? If anyone can confirm this it would be greatly appreciated.
Rob |
not playing cards
| The Following User Says Thank You to Ultramaroon For This Useful Post: | rtalich (09-11-2018) |
#3 | |
not playing cards
Inspect connector carefully. If all ok, swap exhaust sensors. See if the code follows.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | rtalich (09-12-2018) |
#5 | |
Drives: 2017 Toyota GT86 (sorta stock)
not playing cards
Our generous benefactor found a different place to host the content. Updated. Also see my sig line.
| OCV Keeps Failing P000B Fault Code | Gumberculies | Issues | Warranty | Recalls / TSB | 6 | 11-12-2018 08:09 PM |
| Fault Code: U0122 | HubertK | Issues | Warranty | Recalls / TSB | 5 | 09-28-2017 08:49 PM |
| Help!! ECU FAULT Code P0105 | 86King | Issues | Warranty | Recalls / TSB | 9 | 02-13-2017 01:35 AM |
| Fault Code P000B, before I got to the dealer | TURBObro10 | Issues | Warranty | Recalls / TSB | 4 | 11-08-2016 04:29 PM |
| Got ECU fault code U0073. Need help! | xiayu0320 | Issues | Warranty | Recalls / TSB | 4 | 11-18-2015 11:41 PM |
