Old 09-10-2018, 02:20 PM   #1
rtalich
Drives: 2015 BRZ Series.Blue
P0365 Fault Code
I keep getting a P0365 code. Camshaft Position Sensor "B" Circuit Location Bank 1. From what I've been able to gather is that this particular sensor is on the Passenger side and is the sensor on the Intake, correct? If anyone can confirm this it would be greatly appreciated.
Rob
rtalich is offline   Reply With Quote
Old 09-10-2018, 09:54 PM   #2
Exhaust. Also see the link in my sig.
https://gt86stuff.onrender.com/t3Por...00YTB0K0X.html
Old 09-11-2018, 11:48 AM   #3
rtalich
Wow... thank you so much for that information! Exactly what I was looking for. What do you make of an intermittent sensor? It will generate the P0365 code... I'd clear it. It'll go for a day or longer sometimes weeks before I get another code.
Old 09-11-2018, 04:49 PM   #4
Inspect connector carefully. If all ok, swap exhaust sensors. See if the code follows.
Old 08-26-2023, 02:48 PM   #5
blakebrz
Drives: 2017 Toyota GT86 (sorta stock)
Any chance you have an updated link? When I click, it goes dead. I am having the same issue and don't know what to replace or where to look. Thank you!
blakebrz is offline   Reply With Quote
Old 08-26-2023, 02:58 PM   #6
Our generous benefactor found a different place to host the content. Updated. Also see my sig line.
OCV Keeps Failing P000B Fault Code Gumberculies Issues | Warranty | Recalls / TSB 6 11-12-2018 08:09 PM
Fault Code: U0122 HubertK Issues | Warranty | Recalls / TSB 5 09-28-2017 08:49 PM
Help!! ECU FAULT Code P0105 86King Issues | Warranty | Recalls / TSB 9 02-13-2017 01:35 AM
Fault Code P000B, before I got to the dealer TURBObro10 Issues | Warranty | Recalls / TSB 4 11-08-2016 04:29 PM
Got ECU fault code U0073. Need help! xiayu0320 Issues | Warranty | Recalls / TSB 4 11-18-2015 11:41 PM
