Old 11-06-2016, 05:58 PM   #1
TURBObro10
Drives: `15 WRB BRZ
Fault Code P000B, before I got to the dealer
My car suddenly threw a CEL and the Traction control light while cruising yesterday. Ran the CEL and came back with P000B, which seems it could be camshaft position sensor related or possibly something to do with the AVCS? The car is a 2015 BRZ with 11K kms, JDL UEL, Drop in filter, and currently running the OFT Stage 2 tune. Should I try to reflash the tune or clear the code and see if it comes back? Or if I take it to the dealer, should I reinstall the stock manifold and flash back to the stock tune, for warranty purposes. Any advice would be appreciated.
TURBObro10 is offline   Reply With Quote
Old 11-06-2016, 08:51 PM   #2
humfrz
I'd suggest you clear the code and see if it comes back ....... maybe the engine just hic-cupped ........
humfrz
Old 11-06-2016, 09:02 PM   #3
Sort of a catch 22 when throwing a code on a modded/tuned car and then converting back to try to find what is wrong since if the mod/tune was part of what was wrong there will be nothing to find. I would try clearing it and see if it came back. The cam sensor was a fairly common item with the 13s but I don't recall seeing a whole lot of later cars having it pop up.
Old 11-08-2016, 02:02 PM   #4
Scarpa
Drives: 2015 FR-S
I've been having P000C go on and off on a stock '15 with 23k miles. Same symptoms, CEL+TC until I turn car off then CEL only for another couple drive cycles. Haven't had a chance to deal with it yet, though and seems relatively minor aside from the annoying limp mode it's in while TC light is on.
Scarpa is offline   Reply With Quote
Old 11-08-2016, 04:29 PM   #5
calic
calic's Avatar
Drives: Subaru Brz
http://www.ft86club.com/forums/showthread.php?p=2769604
Check the thread
2015 WRB Limited Sti
Instagram: limitedbreeze
calic is offline   Reply With Quote
Code P000B CTB727 Issues | Warranty | Recalls / TSB 15 10-15-2023 12:19 PM
p000b Djratrap Issues | Warranty | Recalls / TSB 8 08-29-2016 02:33 PM
Got ECU fault code U0073. Need help! xiayu0320 Issues | Warranty | Recalls / TSB 4 11-18-2015 11:41 PM
Error code dealer or no dealer acro Software Tuning 4 11-19-2014 05:29 PM
Dealer can't read CEL code Eddie Issues | Warranty | Recalls / TSB 24 11-15-2013 01:05 PM
