Old 02-10-2017, 11:14 PM   #1
86King
Drives: FR-S Monogram
Help!! ECU FAULT Code P0105
ABS, check engine light and Traction control slip light on. Car will not go over 4000 RPM. Fan turns on immediately even when in accessory mode (key in the second position, just before starting it). Read the ECU and it gave me P0105. HELP!!
86King is offline   Reply With Quote
Old 02-11-2017, 12:14 AM   #2
humfrz
For some background information:
http://www.troublecodes.net/pcodes/p0105/
What is the last thing you did to your car (except drive it) ..??
What power mods do you have if any..??
Unless you understand the above reference, it would be time to limp into a dealership, especially if it's still under warranty.
humfrz
86King (02-11-2017)
Old 02-11-2017, 12:58 AM   #3
86King
humfrz
My car was recently in an accident, and had just finished being repaired. In terms of mods, it's pretty much stock right now, other than a K&N Air Filter. The previous owner had it tuned with ECUTEK for JDL UEL Catless headers on 94 octane. The tune is locked to the ECU and I do not believe it was put back to stock... but that still never caused the P0105 code time come on before the accident.
Old 02-11-2017, 01:14 AM   #4
humfrz
So, did the code just appear after the accident repair .. ?? If so, how long (many miles) after the repairs were completed .. ??
Any repairs in or near the engine compartment .. ??
humfrz
Old 02-11-2017, 04:20 AM   #5
steve99
Car has gone into limp mode due to sensor error , P0105 is MAP manifold absolute pressure senssor its the one on the intake manifold , check its plugged in chack vacuum hoses, but its most likely bad map sensor or wiring or connector
The Following 2 Users Say Thank You to steve99 For This Useful Post:
86King (02-12-2017), Ultramaroon (02-13-2017)
Old 02-12-2017, 03:42 AM   #6
86King
humfrz
Yes, code appeared after the repair.
No repairs in or near the engine compartment.
Rear subframe,drivers side rear suspension and axle were all replaced.
The Following User Says Thank You to 86King For This Useful Post:
humfrz (02-12-2017)
Old 02-12-2017, 03:46 AM   #7
86King
I read the ECU with another OBD reader and this time it gave me P0500 (vehicle speed sensor)
Old 02-12-2017, 04:46 AM   #8
steve99
check the wheel speed sensor where the accident damage was, their may also be another sensor on transmission as well as ones on other three wheels for abs and traction control. check sensors wiring and plugs
if you have techstream dealer software it can show readings from the wheel sensors
86King (02-12-2017)
Old 02-13-2017, 01:00 AM   #9
86King
I checked the Speed Sensor on the side the damage was. Other than being a little dirty, it looked physically fine.
Cleaned it and did a continuity test and got no reading, but did the same test on the other side and got a reading (all while the car was off and battery unplugged).
Looks like I need a new speed sensor on that one side?
steve99 (02-13-2017)
Old 02-13-2017, 01:35 AM   #10
steve99
continuity test probably not the best but if thier is a definte difference between all the sensors except one then it a pretty good sign its stuffed
86King (02-13-2017)
Fault Code: U0122 HubertK Issues | Warranty | Recalls / TSB 5 09-28-2017 08:49 PM
Fault Code P000B, before I got to the dealer TURBObro10 Issues | Warranty | Recalls / TSB 4 11-08-2016 04:29 PM
Got ECU fault code U0073. Need help! xiayu0320 Issues | Warranty | Recalls / TSB 4 11-18-2015 11:41 PM
Brake Switch Fault | TSB FIX Dezoris Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 06-11-2014 10:11 PM
Torque fault codes help derka-derka Issues | Warranty | Recalls / TSB 2 05-24-2013 09:07 AM
