Old 08-02-2018, 04:52 AM   #1
Hags86
Drives: Toyota GTS 86
Throttle Position Sensor [Suspected Faulty]
Car occasionally wont rev, just idles and coasts.
I have some logged data that points to it being a faulty throttle position sensor. Do these things fail in practice? Just get the feeling I'm about to start on a wild goose chase.
2013 Toyota 86: 275rwkW
Coyoda Water-to-air Intercooled Turbo with GTX2863. CP Carillo Rods and Pistons. Motec M150 ECU. Motec C125 Dash. Holinger SG 6 Speed Sequential Gearbox. OS Giken LSD. MCA Reds Coilover. AP Racing Essex Sprint Front Brakes. PWR Radiator and Intercooler heat exchanger.
Hags86 is offline   Reply With Quote
Old 08-02-2018, 01:15 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Looks like the only stock part you have is your gas pedal. You might get more help if you move this thread to the swaps section. I doubt the fault lies with the only part that hasn't been touched.
Old 08-02-2018, 06:26 PM   #3
Hags86
My thoughts too. The Motec logging is pretty specific that it's a failed TPS or wiring but that's OEM so probably OK.
Old 08-07-2018, 01:23 PM   #4
Hags86
So I spoke to MoTec to see if it might be a hardware fault of the ECU (reading the wrong voltage on the sensor).
Turns out a failed accelerator pedal is a known fault and they've replaced lots of them on the Toyota 86 Race Series cars. It looks like high lateral load on the pedal from heel-n-toe on downshifts splits a plastic bushing internal to the TPS and one side fails. There are two TPS sensors built in (for safety) and when there is a difference in voltage between the two the ECU stops acceleration.
I'll post this in the tracking section where the heel-n-toe action lives.
Old 08-07-2018, 01:53 PM   #5
steve99
Thanks.
can you activate auto-blip on downshift (rev match) on motec ? , but I gather is locked on 86 series cars
Old 08-07-2018, 06:51 PM   #6
Ultramaroon
not playing cards
Wow! I noticed a few months ago that mine felt a little wobbly. Now I'll have to look at that! Thanks for the heads-up.
Old 08-07-2018, 10:56 PM   #7
ermax
ermax's Avatar
Mine too. Sometimes at full throttle I will feel it shift sideways a tad and go down a little farther. Been meaning to look down there because it’s kind of annoying. I always heal toe so maybe the side loading has gotten to mine.
Old 08-08-2018, 12:24 AM   #8
Ultramaroon
not playing cards
I do too. I smell a mod in our future. :/
Old 08-09-2018, 02:39 PM   #9
Ultramaroon
not playing cards
Checked mine yesterday. Nothing's wrong except for it being plastic. Can't do much for that.
Old 08-11-2018, 09:31 PM   #10
Hags86
So, I installed a new accelerator pedal and the problem remains.
The logs show the Main position voltage OK but the Tracking (safety) one drifting up. I've repinned this to a spare analogue voltage input on the ECU. That will tell me whether it is a wiring problem or a fault on the analogue to digital converter on the ECU.
Old 09-11-2019, 11:48 PM   #11
FR_STEEZ
Drives: 2017 toyota 86
Ever fix the issue. My pedal has a dead space the first few degrees in the pedal and it does wobble a lot cause I always heel toe.
FR_STEEZ is offline   Reply With Quote
Old 09-29-2025, 10:05 AM   #12
TRD83
Drives: 2013 FRS Edelbrock Supercharger
I’m receiving the same fault (P2135) and symptoms ( can’t rev over 2500 rpm) but it will only happen once every 2,000 miles or so.
I’ll restart the car once or twice and the error goes away.
I transferred engine and ECU (not gas pedal) to a different car and the problem followed. Still only happens once every 2,000 or so miles and I’ll clear code and restart the car and it’s fine.
Goose chase continues
2013 FRS, edlebrock supercharger, delicious tune, delicious E85 sensor/ dbox.
2013 FR-S
TRD83 is offline   Reply With Quote
How to calibrate Throttle position sensor FRS? Binary_fission Issues | Warranty | Recalls / TSB 11 04-01-2017 01:37 AM
Cam position sensor harness help me need a part off a donor car kiichiro Engine, Exhaust, Transmission 5 04-23-2014 05:19 PM
faulty a/f o2 sensor sid3way5 Issues | Warranty | Recalls / TSB 5 01-06-2014 11:06 AM
Throttle Position question NoFear99 Engine, Exhaust, Transmission 8 06-07-2013 08:25 AM
Passenger weight sensor faulty? Trashed675 Issues | Warranty | Recalls / TSB 5 01-27-2013 01:20 PM
