Old 04-24-2013, 11:53 AM   #1
NoFear99
NoFear99's Avatar
Drives: FR-S Firestorm
Question Throttle Position question
When we are at wide open throttle with our cars, the throttle position should be to 100% ?
Yesterday with my ecutek logs I saw in the charts table that my throttle position wont go over 80,4% at wide open throttle.
Is this normal ?
I would prefer to have 100% instead !
- 2013 Scion FR-S Firestorm
- 2007 Lotus Exige S 280 Solar Yellow
- 2007 Honda CBR 600RR
- 2002 Bombardier Legend 800SE
Website : http://nofear99.monchar.com
NoFear99 is offline   Reply With Quote
Old 04-24-2013, 12:16 PM   #2
NoFear99
NoFear99's Avatar
My tuner just told me it was normal the throttle position goes to only 80,4%.
He said to check into the ecutek data table for accelerator angle(%) and as long as this one goes to 100% you're fine.
If somebody else have another theory let us know.
Thank You.
Old 04-24-2013, 12:18 PM   #3
mad_sb
Drives: 2013 Asphalt FR-S
that is normal i see the same thing with BRZedit and plain old ODBII scanners. You can easily get LESS throttle plate opening by messing with the torque base tables, but i have yet to get more than about 81% and it fades off as revs climb from a max of around 80% at 4K to high 70's up top.
Old 04-24-2013, 12:18 PM   #4
Gen
Drives: Scion FR-S
That is normal
Gen is offline   Reply With Quote
Old 04-24-2013, 12:32 PM   #5
LeeMaster
Red wine
Drives: Subaru BRZ(R.I.P)
I checked my torque pro app, the throttle only goes 100% if I use extra force to push in the pedal. Not sure if that is a good or a bad thing or if it is even necessary to push it THAT hard.
EDIT: Nevermind, my Impreza does that, the BRZ stays at a maximum 81.4%. I am guessing it has something to do with the DBW vs Cable throttle
LeeMaster is offline   Reply With Quote
Old 06-06-2013, 11:07 PM   #6
smbstyle
smbstyle's Avatar
Drives: 2013 SWP BRZ
Along the same lines as this topic, I just hooked up my Scangauge (OBDII gauge) and noticed my relative throttle maxes out at 69% at wide open throttle, which I thought was odd....
smbstyle is offline   Reply With Quote
Old 06-07-2013, 12:00 AM   #7
Turdinator
Señor Member
Turdinator's Avatar
I wonder if the ECUTEK tunes increase the percentage.
1974 TA22 Celica
2013 86 GT
Old 06-07-2013, 08:44 AM   #8
mad_sb
Nope,
There are multiple Accelerator pedal params and throttle plate params. If your not seeing 100% on the accelerator pedal, your not logging the correct parameter. If your not seeing a max of 82% tapper to 79% for throttle plate, your not logging the correct parameter.
Old 06-07-2013, 09:25 AM   #9
smbstyle
smbstyle's Avatar
Originally Posted by mad_sb View Post
Nope,
Hm, only options on the scangauge I have for throttle position are relative and absolute (%)
Shift position Indicator Ryan86 AFRICA 17 04-12-2013 08:24 AM
The seating position of BRZ is too low to reach at a drive-through-ATM yajin BRZ Photos, Videos, Wallpapers, Gallery Forum 28 07-16-2012 03:18 PM
Headrest position Sigh-on-Rice Scion FR-S / Toyota 86 GT86 General Forum 2 06-15-2012 02:28 PM
