Old 12-09-2015, 04:21 AM   #1
Binary_fission
Binary_fission's Avatar
Drives: FRS
Question How to calibrate Throttle position sensor FRS?
ok as the title says. Ive just innstalled Jackson Racing supercharger kit, everything went smooth, all lines and hoses connected properly, ecu calibrated with their tune, but when car starts it dies right after, in order to keep car on i have to keep gas pedal all the way down and even then engine runs rough like its not gettin enough air or gas so it chokes and dies, now since we took air intake off i stuck my hand into the throttle body to clean it, not knowing that it is electronicaly calibrated.
Ive used search here and google, nothing pops up really except throttle body spacers and such.
Any help would highly appreciate it.
Binary_fission is offline   Reply With Quote
Old 12-09-2015, 04:30 AM   #2
steve99
The throttle plate auto calibrates, all you generally get is a bit of a dead spot for first few drives.
If its stalling its almost certainly a hardware problem like an air leak or maf/map sensor not plugged in etc.
If you have a catch can check that and the vavles it might be sucking air via catch can or lines
Does that kit need a specific MAP sensor change ? did you use the exact MAP sensor required.
If you have a MAF sensor extension harness check it plugged in securely
double check again for vaccuum or boost leaks.
Use you ecutek cable to log and check for ECU error codes
humfrz (12-09-2015)
Old 12-09-2015, 01:13 PM   #3
Binary_fission
Drives: FRS
Thanks for help steve,
No catch cans, all hoses and lines secured, don't think there's leaks but I'm ganna double check today again.
It did come with map sensor extention and unplugged and replugged everything, still didn't do anything to it.
And ecu doesn't have any codes. It looks like everything is fine but car wont stay up
Sent from my SM-N910T using Tapatalk
Old 12-09-2015, 01:24 PM   #4
Nickosport
Drives: 2015 WRB BRZ Premium
Look for air leaks. If you don't find anything, take data logs and be sure to get what's going on when the car dies. I suspect a hardware problem/failure, Jackson's tune has been used by a lot of people without issues.
2015 WRB BRZ - Nameless - Raceseng - Eibach - Whiteline - Cusco - Perrin
Nickosport is offline   Reply With Quote
Old 12-09-2015, 02:41 PM   #5
Binary_fission
Drives: FRS
Ok talked to Chris from jackson from what I told him it's vacuum issue. Ganna double check again and hope that's the issue.
Also i dont really know what to look for in data logs, I'd probably have to take it to them, but hope it won't come to that when I double check vacuum lines
Old 12-09-2015, 02:44 PM   #6
Binary_fission
Drives: FRS
To stay on the topic, thanks Steve for clarifying that.
Old 01-21-2016, 11:56 AM   #7
j0hnnybk01
Drives: Firestorm FR-S
did you find out what it was ?>
j0hnnybk01 is offline   Reply With Quote
Old 01-21-2016, 01:55 PM   #8
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
Post your MAP at idle from a data log.
There is 1 vacuum line that you can't see. It loves to pop off under boost.. It's the evap purge line, and it's hidden under the intake manifold. Make sure to clamp it in place.
From your description, I doubt it's the problem, but it may be related, and if it isn't a problem yet, it will become one as soon as you're on the road.
It's the line with the braided cover, it feeds in just below the throttle body. Clamp both ends.
Steve already covered the rest of the possible issues, but if there is an air leak, this is as likely a place as any.
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 01-21-2016, 06:08 PM   #9
Binary_fission
Drives: FRS
Yes MAF sensor tubing was installed wrong way so it wasn't reading proper air.
But main point of this topic that throttle calibrate itself auto.
And Spartacus is right I heard about that line poping off. Thanks for the tips I hope people find this useful
Old 03-31-2017, 11:50 PM   #10
omar
Drives: 2016 Scion FR-S
Just to clarify. I am having the exact same issue with my engine dying. What exactly is the solution? Could you go more into detail? Would be a big help. Thanks
omar is offline   Reply With Quote
Old 04-01-2017, 01:33 AM   #11
Binary_fission
Drives: FRS
Turn the maf tube other way around.
MAF sensor goes into the tube only one way, but MAF sensor has to be placed that way so it can read air that goes into tube and for that you have to flip the tube not the MAF sensor
Sent from my LG-H918 using Tapatalk
The Following User Says Thank You to Binary_fission For This Useful Post:
Tcoat (04-01-2017)
Old 04-01-2017, 01:37 AM   #12
Binary_fission
Drives: FRS
Tcoat (04-01-2017)
Cam position sensor harness help me need a part off a donor car kiichiro Engine, Exhaust, Transmission 5 04-23-2014 05:19 PM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 08:11 PM
Throttle Position question NoFear99 Engine, Exhaust, Transmission 8 06-07-2013 08:25 AM
