Old 04-22-2014, 05:20 PM   #1
kiichiro
corolla specs/GTR looks
Drives: ooh oooh pretty tail lights
Cam position sensor harness help me need a part off a donor car
Anyone know where I can find a yard or a seller with a discarded main motor harness? One of the sub harnesses is for a cam position sensor plug
K, looking at the motor it's on lower left underside of front cover
I burnt mine up in a small header fire I had, lucky it was not more than a crank seal and a belt, and said harness
The sensor is fine, car works great, I charred the harness six inches including the female connector.
It's fine, works but it's glued into place using rtv until I find a car or a yard where I can snip this connector, and about six inches of wire
Help welcome, no cost too high so long as it's reasonable
SOLD THEM BOTH
Hers: 2007 987S
Mine: 2012 991S
That was fun, thanks Hachi
kiichiro is offline   Reply With Quote
Old 04-22-2014, 05:38 PM   #2
Hawaiian
That guy
Hawaiian's Avatar
Drives: Ultramarine mt FR-S
@DatApex
Ultramarine mt FR-S
P&L stage 1 turbo
Prime Motoring Flex fuel
Jr Tuned 506whp @17psi (e73)
The Following User Says Thank You to Hawaiian For This Useful Post:
kiichiro (04-22-2014)
Old 04-22-2014, 05:52 PM   #3
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
This guys have bought a few FRSs
http://justjapsimports.net/
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 04-22-2014, 06:08 PM   #4
Calum
That Guy
Drives: 2013 asphalt FRS MT
Car-part.com. Just about every scrap yard in North America uses this site.
The Following 2 Users Say Thank You to Calum For This Useful Post:
kiichiro (04-22-2014), Sportsguy83 (04-23-2014)
Old 04-23-2014, 08:07 AM   #5
Sportsguy83
Drives: Limited BRZ
Calum (04-23-2014)
Old 04-23-2014, 05:19 PM   #6
Calum
That Guy
Originally Posted by Sportsguy83 View Post
The Following User Says Thank You to Calum For This Useful Post:
part number for map sensor (vortech kit) cjsporl1996 Forced Induction 0 03-16-2014 11:05 PM
Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor Supra2k Audio/Visual, Electronics, Infotainment, NAV 1 02-26-2014 08:11 PM
Canadian BRZ owers, do you have this Harness for the radio you want to part with? Kayzer Soze CANADA 10 10-03-2013 01:26 PM
Part Number for OEM Scion H11 Foglight Harness FRSHunter Cosmetic Modification (Interior/Exterior/Lighting) 14 07-15-2013 01:01 PM
TPMS Sensor Part Number or Compatibility civicdrivr Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 15 11-07-2012 01:06 PM
