| Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
Drives: Toyota GTS 86
Throttle Position Sensor [Suspected Faulty]
Car occasionally wont rev, just idles and coasts.
I have some logged data that points to it being a faulty throttle position sensor. Do these things fail in practice? Just get the feeling I'm about to start on a wild goose chase.
2013 Toyota 86: 275rwkW
Coyoda Water-to-air Intercooled Turbo with GTX2863. CP Carillo Rods and Pistons. Motec M150 ECU. Motec C125 Dash. Holinger SG 6 Speed Sequential Gearbox. OS Giken LSD. MCA Reds Coilover. AP Racing Essex Sprint Front Brakes. PWR Radiator and Intercooler heat exchanger. Last edited by Hags86; 08-02-2018 at 06:40 AM. |
#2 |
Looks like the only stock part you have is your gas pedal. You might get more help if you move this thread to the swaps section. I doubt the fault lies with the only part that hasn't been touched.
#3 |
My thoughts too. The Motec logging is pretty specific that it's a failed TPS or wiring but that's OEM so probably OK.
Coyoda Water-to-air Intercooled Turbo with GTX2863. CP Carillo Rods and Pistons. Motec M150 ECU. Motec C125 Dash. Holinger SG 6 Speed Sequential Gearbox. OS Giken LSD. MCA Reds Coilover. AP Racing Essex Sprint Front Brakes. PWR Radiator and Intercooler heat exchanger. |
#4 |
So I spoke to MoTec to see if it might be a hardware fault of the ECU (reading the wrong voltage on the sensor).
Turns out a failed accelerator pedal is a known fault and they've replaced lots of them on the Toyota 86 Race Series cars. It looks like high lateral load on the pedal from heel-n-toe on downshifts splits a plastic bushing internal to the TPS and one side fails. There are two TPS sensors built in (for safety) and when there is a difference in voltage between the two the ECU stops acceleration. I'll post this in the tracking section where the heel-n-toe action lives.
#5 | |
Drives: FT86
Thanks. can you activate auto-blip on downshift (rev match) on motec ? , but I gather is locked on 86 series cars |
#6 | |
#7 | |
Mine too. Sometimes at full throttle I will feel it shift sideways a tad and go down a little farther. Been meaning to look down there because it’s kind of annoying. I always heal toe so maybe the side loading has gotten to mine. |
#8 |
I do too. I smell a mod in our future. :/
#9 |
Checked mine yesterday. Nothing's wrong except for it being plastic. Can't do much for that.
#10 |
So, I installed a new accelerator pedal and the problem remains.
The logs show the Main position voltage OK but the Tracking (safety) one drifting up. I've repinned this to a spare analogue voltage input on the ECU. That will tell me whether it is a wiring problem or a fault on the analogue to digital converter on the ECU.
#11 | |
Drives: 2017 toyota 86
#12 |
Drives: 2013 FRS Edelbrock Supercharger
I’m receiving the same fault (P2135) and symptoms ( can’t rev over 2500 rpm) but it will only happen once every 2,000 miles or so.
I’ll restart the car once or twice and the error goes away. I transferred engine and ECU (not gas pedal) to a different car and the problem followed. Still only happens once every 2,000 or so miles and I’ll clear code and restart the car and it’s fine. Goose chase continues 2013 FRS, edlebrock supercharger, delicious tune, delicious E85 sensor/ dbox.
2013 FR-S
Edelbrock Supercharger |
| How to calibrate Throttle position sensor FRS? | Binary_fission | Issues | Warranty | Recalls / TSB | 11 | 04-01-2017 01:37 AM |
| Cam position sensor harness help me need a part off a donor car | kiichiro | Engine, Exhaust, Transmission | 5 | 04-23-2014 05:19 PM |
| faulty a/f o2 sensor | sid3way5 | Issues | Warranty | Recalls / TSB | 5 | 01-06-2014 11:06 AM |
| Throttle Position question | NoFear99 | Engine, Exhaust, Transmission | 8 | 06-07-2013 08:25 AM |
| Passenger weight sensor faulty? | Trashed675 | Issues | Warranty | Recalls / TSB | 5 | 01-27-2013 01:20 PM |
