Old 06-03-2018, 11:36 PM   #1
NyX_Nick
Drives: 2013 WRB BRZ Stock, 1991 Toyota MR2
Hissing/ticking sound under load
Hey all, I installed my nrw exhaust today which consists of:
Gruppe-S UEL
Tanabe Overpipe
Invidia Resonated Front Pipe
GReddy Supreme SP catback
With OFT V4.03 Stage 2+ Tune.
I noticed when under load, I can hear a hissing/ticking that sounds like it's coming from under the car.
It gets quieter over time as the car heats up which leads me to believe it's an exhaust leak, but I can't hear it at idle, or startup/ turn off, and there's also no hesitation or lack of acceleration, the power is all there.
Does it sound like an exhaust leak? I also installed an AVO Panel Filter and had to fight it a bit to get it in as it was quite snug. Could it be coming from that?
Sent from my CLT-L04 using Tapatalk
NyX_Nick is offline   Reply With Quote
Old 06-03-2018, 11:51 PM   #2
Ultramaroon
not playing cards
Ultramaroon's Avatar
Doesn't sound like anything until we hear a recording. :/
Exhaust-port leaks do tick. That's a strong sign.
Thin headers hiss, or maybe more whoosh at high flow. That's likely normal.
Old 06-04-2018, 09:34 AM   #3
NyX_Nick
I'll get a sound recording/video once I get off of work today
Old 06-04-2018, 10:10 AM   #4
cjd
cjd's Avatar
Drives: 2017 BRZ
Logs should show you if you have an exhaust leak.
Thin headers and the DI system could easily be what you hear.
Old 06-04-2018, 10:59 AM   #5
jonboy99
jonboy99's Avatar
Drives: Black Panda BRZ
I get a hissy kind of sound with my OFT headers. I haven't checked for a leak, but I suspect it's just the sound they make.
jonboy99 is offline   Reply With Quote
Old 06-04-2018, 01:23 PM   #6
Weigaldo
Weigaldo's Avatar
Drives: 2016 Steel AT FRS
I have an "air escaping" noise that I can only hear under light throttle/low rpm when there is something next to me for the sound to bounce off of. Sounds like it's coming from under the passenger side of the car. I went under the car probably 5-6 times to check for leaks before I accepted that's just how my setup sounds. The only other thing I could think of is movement at the front/mid pipe connection where the donut loses its seal. But if it's sealing at idle, I'm not concerned about that.
Weigaldo is offline   Reply With Quote
Old 06-04-2018, 08:12 PM   #7
NyX_Nick
Took this quick video of it after work today on my phone, fresh off a cold. You can hear it when the gas is pressed
Old 06-04-2018, 08:31 PM   #8
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
im not hearing it. if its ticking it could be an exhaust leak or injectors
Breadman is offline   Reply With Quote
Old 06-05-2018, 09:01 PM   #9
NyX_Nick
On a cold-start, especially in the morning, I hear a tick when on-throttle, just momentary when the gas peddle is pressed in then it goes away.
I believe it may be the gaskets where the header meets the head not sealing properly, as it goes away as the car heats up, and if I drive it for more than 20-30 mins, goes away completely.
I remember having these symptoms on my MR2 before replacing the manifold gasket.
Either way, I'm sending my car out on Friday to have the coilovers installed/aligned at a Subaru/Porsche specialist shop here, and I when I mentioned it to them, they said they'd take a look at it, and the connections/welds and see if they can find the leak
ticking sound with el header install. fluffy-reindeer-slayer Engine, Exhaust, Transmission 10 05-11-2021 01:13 AM
ticking sound when taking off???? 93frs BRZ First-Gen (2012+) — General Topics 9 02-18-2015 02:05 AM
ticking sound when taking off???? 93frs Scion FR-S / Toyota 86 GT86 General Forum 5 02-09-2015 12:50 AM
Clicking/ticking sound when in reverse Kauf Issues | Warranty | Recalls / TSB 0 01-03-2015 09:14 PM
Ticking sound, under load norsamerican Issues | Warranty | Recalls / TSB 1 12-19-2013 03:53 PM
