Old 02-08-2015, 03:29 PM   #1
93frs
Drives: Raven frs
ticking sound when taking off????
Right when im taking off mainly at low rpm i hear i light ticking(ticking/clicking)sound from ppassenger side in the rear. Sometimes even when at the low rpm in 2nd and 3rd but just in the begining of the gear . And sometimes it doesnt do it at all. Anyone have this problem ???
93frs is offline   Reply With Quote
Old 02-08-2015, 03:47 PM   #2
There have been a few threads on here on the subject. The answers ranged from something stuck in a tire (the most frequent problem) to bad axles (the rarest problem) and just about everything in between. If it keeps up just take it in and have it checked since trying to diagnose a noise over the internet is actually pretty futile even if there are guys that will try.
pdhami (02-08-2015)
Old 02-08-2015, 05:08 PM   #3
G.I.Choe
Drives: 2013 Scion FRS Argento
I had this exact problem. Took it to a dealer while I was under warranty, and after they had had it for a few hours, called me to let me know that one of the bolts in the axle wasn't torqued to spec. They retightened everything, and I haven't heard it again in the two years since.
G.I.Choe is offline   Reply With Quote
The Following User Says Thank You to G.I.Choe For This Useful Post:
Tcoat (02-08-2015)
Old 02-08-2015, 09:56 PM   #4
strat61caster
strat61caster's Avatar
Re-torque the axle nut usually fixes it. A good dealership should do it no questions asked in less than an hour.
Most dealerships are not that good.
Old 02-08-2015, 10:11 PM   #5
edeekeos
edeekeos's Avatar
Drives: 2014 Pearl BRZ Limited
My dealership claimed it was a loose spare tire nut. So I re-torqued the axle nut, and it went away. Bunch of FUCKING RETARDS I swear..
| OFT & Stg2 e85 Tune | Perrin Intake Tube & High Flow Filter | Perrin Lightweight Crank Pully |
| Tomei UEL Header/Overpipe | HFC/Perrin Catback | Tom's Tails | Enkei RPF1's | RS*R SuperDowns |
edeekeos is offline   Reply With Quote
Old 02-09-2015, 12:50 AM   #6
93frs
Drives: Raven frs
Ima take it in since its under warranty hopefully no hastle, and hopefully it is what you guys are saying also, dam seems like a simple issue
ticking sound with el header install. fluffy-reindeer-slayer Engine, Exhaust, Transmission 10 05-11-2021 01:13 AM
Clicking/ticking sound when in reverse Kauf Issues | Warranty | Recalls / TSB 0 01-03-2015 09:14 PM
Ticking sounds from exhaust when off Kefu Issues | Warranty | Recalls / TSB 26 12-20-2013 02:11 PM
Ticking sound, under load norsamerican Issues | Warranty | Recalls / TSB 1 12-19-2013 03:53 PM
ticking noise? iHeartmyFR-S Issues | Warranty | Recalls / TSB 13 04-18-2013 05:42 PM
