| BRZ First-Gen (2012+) — General Topics All discussions about the first-gen Subaru BRZ coupe |
Drives: Raven frs
ticking sound when taking off????
I get a ticking sound comeing from the passenger t rear side at low rpm when im taking off. Sometimes 1st through 3rd. At the very beggining of the gears. ANYONE experience this issue. Its supper anoying !!!
Drives: '22 BRZ
How many miles on the car? Lowered? I ask because it seems like the CV joints in these cars are made of cheese and they fail...
Drives: '13 BRZ, '06 997, Other Things(TM)
Is the sound kind of like a playing card stuck in a bicycle wheel?
Drives: 2017 BRZ
I always always check the tires first... easy to get a stone or something caught in the treads causing noise. Once it turned out to be a nail...
Of course, "ticking sound" is rather vague so I could easily be completely off base. C |
Drives: Raven frs
Bone stock never dropped, litteraly a light tick sound. A few ticks at a time, im hearing it could possibly be axle nut
Drives: '14 SWP BRZ Limited
Almost sounds like a decently heavy peace of metal hitting other metal? Doesn't seem to sync with the rotation of the tires or anything?
Mine does that, I am lowered but the install was definitely done right (by a Subaru tech). I thought one of my TPMS sensors was loose since I need to take it in as my light is on even though all the pressure is correct. But yes, it's very annoying.
Run Away!
Drives: 2015 Subaru BRZ Limited
My BRZ recently started making that noise. I thought I was going insane and I couldn't find anything in regards to that noise. Do you have any ideas as to what/why it's making that card on bicycle wheel noise?
Drives: 2013 BRZ Limited White
Have you guys checked the tires for nails or other debris? If you have a metal object like a nail protruding, that will cause ticking that increases with speed. It might disappear in higher gears due to road noise. My jeep had issues with ball joints, which caused the exact same symptom. Had me searching the tires for days. Turned out to be ball joints causing the tire to wear so badly it smacked the ground.
#9 | |
![]() It's on the list of things to investigate when the car goes into the dealer for its next oil change. |
#10 |
Drives: 2014 Subaru BRZ
Must be the buttons on the seats to hold the seatbelts.
| ticking sound with el header install. | fluffy-reindeer-slayer | Engine, Exhaust, Transmission | 10 | 05-11-2021 01:13 AM |
| ticking sound when taking off???? | 93frs | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 02-09-2015 12:50 AM |
| Clicking/ticking sound when in reverse | Kauf | Issues | Warranty | Recalls / TSB | 0 | 01-03-2015 09:14 PM |
| Ticking sound, under load | norsamerican | Issues | Warranty | Recalls / TSB | 1 | 12-19-2013 03:53 PM |
| ticking noise? | iHeartmyFR-S | Issues | Warranty | Recalls / TSB | 13 | 04-18-2013 05:42 PM |
