Drives: fr-s and tc2
ticking sound with el header install.
Just replaced my borla uel's with hks el headers. what a difference in sound it made.I'm not shure if i like it or not.my question is for guys that run el headers.i hear tick tick tick sound while under acceleration. I thought it was an exhaust leak but I inspected everything and everything seated properly and is clean, no signs of a leak anywhere.no black carbon on anything.is this just the injectors I'm hearing?the exhaust is much quieter than the uel.mabe I just didn't hear it before. Any input would be great.
Drives: 2013 MT Asphalt FRS
Maybe it is an exhaust leak? I had the same problem when I put my headers.
Turning is for Nerds
Drives: 35 characters is not enough
A video would be helpful...
I'll try and get that up soon
Found the leak using water soap solution.thanks for the help everyone.
So where did the leak end up being, at the head flanges or the overpipe connection?
Noodleking
Drives: 2013 Firestorm FRS
I think I have the same issue-- going to check for more leaks soon :P
2013 Firestorm FR-S, Kraftwerks C38 kit, FT-86 UEL Catted Headers, TRD D-Tip cat-back, Vibrant 1140 Resonator, Exedy Stage 1 Normal/smoother clutch that replaced the Stage 2 3-puck clutch, Exedy Lightweight flywheel, DSS carbon fiber driveshaft, TEIN springs on performance package Sachs dampers, Megan Racing Inner tie rods, 17x8 +35 Enkei Silver RPF1's, OS-Giken 1.5-way diff, J-Luth steering wheel and now a GKTech angle kit-- which rubs.
Drives: 2017 PP BRZ
#10 |
Noodleking
Ended up getting it checked out at a shop-- had a leak at the flange-- it seemingly fixed the added ambient sound in the cabin with most of the sound coming out the rear. The tick between 2k-3k in like 3rd or 4th gear, still exists... might be just the way it is with the EL headers. Not sure really, but I can hear it more now than I could before....
#11 |
Drives: Corolla GT
Without exhaust shielding you will end up with some added noise. I did put exhaust wrap to reduce the engine bay temps and some sound deadening. It helps a bit.
But overall you will have to live with it.
| Stock catback w/header sound OK? | xDanger_208x | Engine, Exhaust, Transmission | 59 | 10-07-2015 01:40 AM |
| tomei UEL header and overpipe sound | mokinbird87 | Engine, Exhaust, Transmission | 11 | 04-07-2015 09:05 PM |
| Ticking sound, under load | norsamerican | Issues | Warranty | Recalls / TSB | 1 | 12-19-2013 03:53 PM |
| Will 3" header back = deeper sound? | djliquidsteele | Engine, Exhaust, Transmission | 3 | 11-13-2013 09:31 PM |
| JDL EL header sound, quick clip. | Hardrock4445 | Engine, Exhaust, Transmission | 20 | 03-29-2013 06:08 PM |
