Old 05-27-2018, 10:49 AM   #1
Kojiap1
Drives: 10 Series
Fender brace install help
It seemed pretty simple, however the 3rd point has me stuck. I can’t seem to find a solution to bolt the 3rd point down, everything is covered. Any ideas?
M
AKA koji187 on club4ag, Hachiroku.net, mr2oc, clublexus, zilvia, nico
13 FRS 10 series
Edelbrock supercharged
Kojiap1 is offline   Reply With Quote
Old 05-27-2018, 08:10 PM   #2
Mr.ac
[insert cool phrase here]
Mr.ac's Avatar
Drives: BRZ Premium
Drill a hole for it.
Also, don't know how to say this but... fender braces are a scam.
Old 05-18-2020, 08:58 PM   #3
Setgo
Setgo's Avatar
Drives: '13 Subaru BRZ Crystal Black Silica
M
You have it installed incorrectly, that one is for the passenger side.
Setgo is offline   Reply With Quote
Old 05-18-2020, 11:15 PM   #4
evomike
Drives: frs
On a unibody car they absolutely stiffen the chassis and do exactly what they are designed to do.
evomike is offline   Reply With Quote
Old 05-19-2020, 02:18 AM   #5
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
There has never been any proof/testing on said products.
The only claims comes from the company that sells them.
Use your own logic and look, what exactly is it bracing?
Old 05-19-2020, 10:05 AM   #6
evomike
Drives: frs
it is bracing the front upper rail to the A-pillar, it makes complete sense that it works and what it does.
Old 05-19-2020, 11:21 AM   #7
pope
has a funny hat
Drives: 2014 BRZ Limited
I'm new to this platform and I am unfamiliar with the specific flex areas of the ft86 chassis, but that brace appears parrot existing structure without introducing any new triangulation and relies on a couple small bolts on one surface. Without plating the inner and outer surfaces, sleeving the bolts to avoid crushing the structure, and through-bolting the brace to the structure, I do not see how that brace can offer more than placebo levels of reinforcement.
In the Fox Mustang community it was common to fully seam weld the chassis and add plates in key strategic areas to increase stiffness. If I wanted to stiffen the upper rail/a-pillar that's how I'd start. (Fox Mustangs are wet noodles compared to these cars, so... yeah).
pope is offline   Reply With Quote
Old 05-19-2020, 11:24 AM   #8
RayRay88
Drives: 2017 86 860 Special Edition
These helped on vehicles from 90's and earlier. Where you could visibly see the deflection in the front shock towers and stampings. They're pretty useless on modern cars. You can categorize them with strut bars.
RayRay88 is offline   Reply With Quote
Old 05-19-2020, 05:10 PM   #9
PulsarBeeerz
Drives: JRSC BRZ SOLD
Don't strut tower braces come stock a lot of modern sportier cars though?
PulsarBeeerz is offline   Reply With Quote
Old 05-19-2020, 05:40 PM   #10
RayRay88
It's a mixed bag. You'll see a lot more triangulation linking shock towers to firewalls. There is a NVH penalty for a strut tower. If a manufacture deems it necessary to control deflection it will but you'll see these mostly in hotted up econo-platforms that don't necessarily have the rigidity from the get go.
TBH, sometimes it's just a ricey dressing like faux carbon, diffuser garnishes, fake exhaust tips and fake vents.
Old 05-19-2020, 07:51 PM   #11
Mr.ac
Mr.ac's Avatar
Drives: BRZ Premium
Guess google could not find anything to back up your claims. Because it's a scam.
Old 05-19-2020, 09:26 PM   #12
evomike
Drives: frs
Whatever you wanna think my man, makes no difference to me
Old 05-21-2020, 08:56 PM   #13
Ernest72
Drives: 16 Silver BRZ, 04 Silver WRX wagon
Not scientific, but when I put them on my 04 WRX you could feel them when pushing the car. I have a few turns near my house that I can push the car before and after installs. Now could be butt dyno, but I am very skeptical of things as well. I would say they might not be worth it for DD, but I think every little bit helps. Plus an 04 WRX chassis is not as stiff as a BRZ. Money vs benefit is always a subjective thing.
Ernest72 is offline   Reply With Quote
Cusco Differential brace install question (SOLVED) Sportsguy83 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 07-09-2016 04:14 PM
FS: Cusco Front Strut Tower Brace with Master Cylinder Brace / Adj Chassis Brace VoiD Brakes, Suspension, Chassis 2 03-16-2016 04:19 PM
Install guide for Cusco Dif Brace? empower-auto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-01-2014 05:11 PM
Rear bumper brace install wootwoot Suspension | Chassis | Brakes -- Sponsored by 949 Racing 3 09-16-2013 02:41 PM
anyone install cusco front member power brace? three3y3wrbbrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-03-2013 12:49 AM
