Old 06-12-2013, 04:06 PM   #1
empower-auto
Kouki-Monster
empower-auto's Avatar
Install guide for Cusco Dif Brace?
http://ft86speedfactory.com/cusco-re...brace-719.html
Instructions are super Japanese. Has anyone installed this yet? Would like to have mine in this weekend and don't want to gooby it up.
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 06-12-2013, 04:12 PM   #2
Hanakuso
Post up the instructions and i'll try to help
Hanakuso is offline   Reply With Quote
Old 06-13-2013, 11:50 AM   #3
RallySport Direct
RallySport Direct's Avatar
Drives: 2014 Widebody Cosworth FR-S
The install is not too bad, I would say the hardest part was getting the supplied nuts up in the rear subframe as it is a very very tight fit up there. We removed the lower control arm from the subframe to help get a bit more room, but it was still difficult to hold the nut in place and thread in the bolt.
That is how it will sit on the rear subframe, the center holes on the mount will bolt right up to the diff, just support the diff, remove the 3 bolts, and bolt the brace up to the subframe/diff. The 2 outer most holes will include the hardware which go through factory holes in the subframe, but these are the tricky ones due the small space for access.
Hope this helps
Thanks,
Rick
RallySport Direct is offline   Reply With Quote
Old 06-17-2013, 02:37 PM   #4
empower-auto
Kouki-Monster
Hope this helps
Thanks,
Rick
How did the car feel after?
Rich Anderson
EMPOWER AUTO
Old 06-17-2013, 02:48 PM   #5
RallySport Direct
Amazing! It essentially eliminated almost all movement from the rear diff, but it did add quite a bit of harshness for sure. I personally would not install this brace on my daily driver, and would go for the bushings, but for someone wanting that raw feel this would be the one to go with.
Thanks,
Rick
Old 06-17-2013, 02:51 PM   #6
empower-auto
Kouki-Monster
Thanks,
Rick
Giggity .. can't wait to put mine in.
Rich Anderson
EMPOWER AUTO
Old 12-01-2014, 05:11 PM   #7
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
http://www.cuscousainc.com/downloads...rz_zn6_zc6.pdf
TRD brace set, or Cusco? TuxedoCartman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 33 01-12-2016 11:58 AM
FS: Cusco Power Brace UncleFester Brakes, Suspension, Chassis 7 03-14-2014 10:58 AM
anyone install cusco front member power brace? three3y3wrbbrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-03-2013 12:49 AM
Cusco Engine Mounts and Cusco Rear Diff Brace - Stiffen up your BRZ/FR-S!!! RallySport Direct Transmission and Driveline 10 03-12-2013 02:11 PM
