Old 05-02-2013, 01:39 AM   #1
three3y3wrbbrz
Kra-ZMaRin€
three3y3wrbbrz's Avatar
Drives: 13 wrblue brz limited 6mt
anyone install cusco front member power brace?
Got a cusco fm power brace and wondering if anyone has instaled one and possiblybly also the front lower armrs.
any commentary to its affects if any noticeable?
im also curious to know if the aluminum scratch plate fits back over it once the brace is bolted down?
thanks
three3y3wrbbrz is offline   Reply With Quote
Old 05-02-2013, 01:43 AM   #2
himynameisdevin
himynameisdevin's Avatar
Drives: Asphalt Fr-s
Yea all the underpanels fit over it no problem.
I put all my bracing in at the same time as long with my coils. Kinda hard to tell what did what. But it's felt much different. I'm sure the bracing is a big help
#Koyorad
----Build Thread Link----
Instagram: himynameisdevin
himynameisdevin is offline   Reply With Quote
Old 05-02-2013, 01:49 AM   #3
Panman
Panman's Avatar
Drives: 86 GTS
What, underbody bling that no-one can see?
Panman is offline   Reply With Quote
Old 05-02-2013, 02:10 AM   #4
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
I have em both. Everything fits perfect and all stock belly pans go back into place as normal. I am now using the GTSpec lower control arm braces with cross brace in place of the Cusco lower arm braces. Mine is considerably more rigid than before the bracing but I have significant rear bracing as well. Vehicle is tied to the road very well. Meaning the vehicle is transmitting exactly what is happening at the tires and road surface.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
Old 05-02-2013, 03:39 AM   #5
Xauterus
Drives: GTS 86 Galaxy Blue
Yeah I have all the underbody bling from cusco that nobody can see. Car feels stiff, but not so much more than stock. I am hoping its going to be helping the chassis stiffness last a lot of years.
Xauterus is offline   Reply With Quote
Old 05-02-2013, 05:41 AM   #6
three3y3wrbbrz
Kra-ZMaRin€
Wow ok great...thought the pannels would be able to go back on.
ya i too expect to install those two braces as well as some in the rear and strut towers as well as wheels and coils all at once. So i cant wait to see the total effects.
thanks
Old 05-02-2013, 05:43 AM   #7
three3y3wrbbrz
Kra-ZMaRin€
Mind telling us what set of coils you set up...and at what specs ride height spring rates ...how you set up the front and rear
thanks
Old 05-02-2013, 07:26 AM   #8
mrk1
Drives: Sterling BRZ Ltd
I love the gains from chassis bracing. I may be more sensitive then some but I think bracing is a great mod. Cars feels much more planted and holds a line better in long sweepers.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
Old 05-02-2013, 07:36 AM   #9
schtebie
Drives: CBS BRZ Limited
You guys were able to get the cardboardish panel to go back on? Hmm.. Maybe I should try putting mine back in...
schtebie is offline   Reply With Quote
Old 05-02-2013, 03:10 PM   #10
himynameisdevin
thanks
I got the hks hipermax. Originally I thought it was a 8k/6k spring rate but recently I read it's 6k/4k. Which makes alot more sense to me. I think I dropped it about 2in and dampening set to about half all around. I can measure fender to groin when I get the chance.
#Koyorad
Old 05-02-2013, 03:11 PM   #11
himynameisdevin
Ground** LOL not groin
#Koyorad
Old 05-02-2013, 03:55 PM   #12
three3y3wrbbrz
Kra-ZMaRin€
Lol
cool so the front is 8k ..if so how does it feel being stiffer in the front.
compared to the stock set up
thanks
Old 05-02-2013, 03:57 PM   #13
usptwins
Toyota Soul
usptwins's Avatar
Drives: 96 taco
No replacement for Displacement??? Tell that to the people with a 2JZ.
usptwins is offline   Reply With Quote
Old 05-02-2013, 04:05 PM   #14
three3y3wrbbrz
Kra-ZMaRin€
Originally Posted by usptwins View Post
Ok stand by...
you wont b impressed
TRD brace set, or Cusco? TuxedoCartman Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 33 01-12-2016 11:58 AM
FS: Cusco Power Brace UncleFester Brakes, Suspension, Chassis 7 03-14-2014 10:58 AM
Cusco Engine Mounts and Cusco Rear Diff Brace - Stiffen up your BRZ/FR-S!!! RallySport Direct Transmission and Driveline 10 03-12-2013 02:11 PM
FS: [VIC] *NEW* Cusco Front Strut Brace w/ Brake Cylinder Stopper green_comet Australia Classifieds 1 12-11-2012 10:10 PM
