Old 07-07-2016, 11:09 PM   #1
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Cusco Differential brace install question (SOLVED)
Edit: Re-installed and 1000% confirmed, the lip goes into the hole in the subframe.
For those who have installed the brace, the nuts that go inside the subframe have one flat side and the other has a small "lip". The guide has no clear instructions on how which side is supposed to makes contact with the subframe. I initially installed it with the flat side (side with no lip) towards the subframe which makes sense....
But I was looking at it today, and it got me thinking if the "lip" on the other side of the nut is supposed to be the side mating to the subframe, and the nut "lip" goes through the subframe hole to keep the nut centered?
Any ideas? I tried finding pictures of the nuts but couldn't find ones that clearly show the lip. Hopefully someone who has done the install understands what I'm talking about and can chime in. Below are the install instructions.
Thanks.
http://www.cuscousainc.com/downloads...rz_zn6_zc6.pdf
Old 07-08-2016, 02:36 AM   #2
gramicci101
Off Topic
Edit: never mind, I'm a dumbass.
Old 07-08-2016, 02:44 AM   #3
Sportsguy83
Drives: Limited BRZ
Originally Posted by gramicci101 View Post
Cusco's site shows the brace curving down. Given that and the fact that one side has one bolt while the other has.....
Yes sir I agree, but that is not the question. Page 5 of the install guide shows the nut I'm asking about. It goes inside the subframe and the question is does it go with the flat side facing the subframe and being the contact surface or is the other side of the nut, the one with a lip, the one supposed to be the contact surface which should allow the lip to slip into the subframe hole. That nut is for the bolts that are held to the subframe (one on each corner of the cusco brace), not for the three bolts that hold the diff.
Thanks for the commenting.
Old 07-08-2016, 08:11 AM   #4
wparsons
wparsons's Avatar
Is the lip like the like what you see on the wheel hub (goes into the center bore of the wheels)? If so, I would put it in whichever direction lets the lip center the nut in the subframe.
flickr
The Following User Says Thank You to wparsons For This Useful Post:
Sportsguy83 (07-08-2016)
Old 07-08-2016, 09:17 AM   #5
Sportsguy83
Drives: Limited BRZ
Yes, it's basically a lip like the hub. I'll re-install it today, make sure the lip indeed fits in the hole and report back.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
wparsons (07-11-2016)
Old 07-08-2016, 01:37 PM   #6
Sportsguy83
Drives: Limited BRZ
Thanks to all who answered.
Old 07-08-2016, 02:01 PM   #7
Yoniyama
Drives: BRZ 2018
Now that the brace has been correctly installed.
I have thought about getting one, too, so I would be grateful if you could provide feedback on the effectiveness of this mod.
Thanks.
Yoniyama is offline   Reply With Quote
The Following User Says Thank You to Yoniyama For This Useful Post:
zc06_kisstherain (07-08-2016)
Old 07-09-2016, 04:14 PM   #8
Sportsguy83
Drives: Limited BRZ
Thanks.
Even how from how it was installed before it's an absolute must have mod if you are making good power. It helps a lot to minimize wheel hop and put the power down.
It does increase NVH, but when you're making power and already have flywheel chatter, stiffer motor mounts, stiffer shifter, it's just one more piece to help performance. The NVH is not absurd, just a bit more whine while cruising and some clanking noises when coming off a stop. They don't bother me really.
Sent from my Nexus 6P using Tapatalk
The Following 2 Users Say Thank You to Sportsguy83 For This Useful Post:
wparsons (07-11-2016), Yoniyama (07-10-2016)
FS: Cusco Front Strut Tower Brace with Master Cylinder Brace / Adj Chassis Brace VoiD Brakes, Suspension, Chassis 2 03-16-2016 04:19 PM
Install guide for Cusco Dif Brace? empower-auto Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 12-01-2014 05:11 PM
Cusco Front Strut Bar with MC stopper and Cusco Power Brace edsbreezy Brakes, Suspension, Chassis 2 03-06-2014 11:06 PM
anyone install cusco front member power brace? three3y3wrbbrz Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 05-03-2013 12:49 AM
Cusco Engine Mounts and Cusco Rear Diff Brace - Stiffen up your BRZ/FR-S!!! RallySport Direct Transmission and Driveline 10 03-12-2013 02:11 PM
