Old 05-26-2018, 02:40 PM   #1
Evangelion
Drives: 2017 GT86
Map scaling isntructions with Ecutek unclear
I just got an omni 3 bar map sensor since I recently got boost, I'm trying to rescale the values but I can't even get to that part. I'm trying to follow this guide but it doesn't even tell you specifically what to do. I've been messing around with the program for a whole day and can't figure it out. Can anyone help me?
https://ecutek.zendesk.com/hc/en-gb/...sor-Re-scaling
Evangelion is offline   Reply With Quote
Old 05-26-2018, 03:28 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
Have you done the tune yourself or do you have a tune provided by someone? The fact you're asking this is a little worrying....
.: Stealth 86 :.
Kodename 47 DJ:
Old 05-26-2018, 03:56 PM   #3
Evangelion
Drives: 2017 GT86
The tune was provided.
Old 05-26-2018, 06:03 PM   #4
steve99
If you have a 3 bar map then substitute in the offset and voltage multiplier values for a 3bar map into the tune tavles shown in the ecutek help file you referenced. Save tune to new name your done.
Check the boost pressure with ignition on , but engine not running is 1 bar ie atmostspheric pressure. If its way different then scaling and map sensor not matched .
Tuning turbo cars your running a fine line even small changes can result in engine destruction be sure you understand what your doing and check carefully
Old 05-26-2018, 10:54 PM   #5
Evangelion
Drives: 2017 GT86
I do have a 3 bar and understand what to do, it's just I don't see an option where I can click on and change the values... where are the settings located? Are you opening an existing rom or?
Old 05-26-2018, 10:58 PM   #6
Evangelion
Drives: 2017 GT86
This is what shows for me, I can only check and un-check things in the boxes, it does not let me directly change values there:
Old 05-27-2018, 12:55 AM   #7
steve99
Haha, that cause your ecutek tune is locked mate :-)
99.9% of ecutek tunes are locked, ie all you can do is flash it amd lg parameters, you cannot edit ot look at thte tune tables. This protects the tuners work.
Its not like opensource like oft or tactrix where every thing is open
You will need to get your tuner ro change tune for 3bar map
Old 05-27-2018, 01:02 PM   #8
Evangelion
Drives: 2017 GT86
Ah... I guess there's nothing I can do then. This map was for my old 2.5 map sensor, do you think I can drive my car just fine with a 3 bar? The car starts but I am just hesitant on taking it out.
Old 05-27-2018, 01:51 PM   #9
tomm.brz
Drives: brz 2017 hksv2
i think you REALLY need to change those 2 values on the map if you put the 3bar map sensor. Not really safe to drive like that specially with FI
Old 05-27-2018, 02:14 PM   #10
Evangelion
Drives: 2017 GT86
This tune is not for a stock map sensor, it was for a 2.5 bar which I had on for FI but it was throwing weird codes so my tuner recommended me getting a 3 bar.
Old 05-27-2018, 02:41 PM   #11
Evangelion
Drives: 2017 GT86
Is there anything I can do to edit my own tune? My car is just sitting there because my tuner responds only through email maybe twice a week and since its a long weekend I don't want to be stuck at home..
EDIT: I ended up just swapping out my 3 bar map back to my 2.5 bar map since my tuner gave me a tune for that one instead and I'll just wait out the 3 bar map.
Old 05-27-2018, 06:35 PM   #12
Kodename47
Kodename47's Avatar
Drives: UK GT86
What codes is it throwing? I don't see how a 3 bar MAP sensor is going to stop codes being caused.
No, there is nothing you can do to edit your own tunes.
.: Stealth 86 :.
Kodename 47 DJ:
Maf Scaling VGI Tool Phantobe Software Tuning 14 04-30-2019 03:55 PM
MAF scaling, showing you what i cam up with trdric Software Tuning 24 06-29-2017 12:10 PM
What MAF scaling says about your intake BuBlake Software Tuning 27 12-09-2014 05:01 AM
BRZEdit MAP scaling jamesm Software Tuning 13 10-02-2013 12:43 PM
