Old 08-26-2013, 01:40 PM   #1
jamesm
BRZEdit MAP scaling
My tuner is having a hard time figuring out how to scale the MAP sensor (4-bar omni) on BRZEdit. Is MAP sensor scaling officially supported by BRZEdit? Maybe @epifan can chime in? Thanks.
Old 08-26-2013, 02:31 PM   #2
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
@mad_sb
Old 08-26-2013, 03:16 PM   #3
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I will await @mad_sb 's response. These kind of questions are the reason I haven't bought BRZedit yet to give tuning my car a shot.
Old 08-26-2013, 03:17 PM   #4
ft_sjo
Drives: GT86
Yes the scaling tables are in there. What problem is he having?
Old 08-26-2013, 03:29 PM   #5
mad_sb
Drives: 2013 Asphalt FR-S
Yeah, there are two tables. One lists the zero volt offset and the other is the volts per bar. It must be a linear output sensor. They are in the 1d tables. Shoot me the sensor model number and specs via pm if you want me to try and figure it out.
EDIT, I found this from a real quick search. this should be what he needs will verrify when i get home:
bar/volt .833
offset (bar) .012
Easy enough to test, check an external barometer, key on engine off turn on logger, compare reading
Old 08-26-2013, 03:34 PM   #6
jamesm
bar/volt .833
offset (bar) .012
it's an omnipower 4-bar map. thanks for your help!
Old 08-26-2013, 03:36 PM   #7
Sportsguy83
Drives: Limited BRZ
bar/volt .833
offset (bar) .012
This guy is the MAN!
Old 08-26-2013, 03:37 PM   #8
King Tut
NASA SpecE30 Racer
King Tut's Avatar
This.
Old 08-26-2013, 03:46 PM   #9
mad_sb
Yeah, post the model number if you can the data i found was for a perrin omni-4bar. May or may not be the same.
Old 08-26-2013, 05:32 PM   #10
coyote
coyote's Avatar
Drives: Slowly
bar/volt .833
offset (bar) .012
I'm almost certain that is correct.
Can check later today.
Sent from my Nexus 4 using Tapatalk 2
coyote is offline   Reply With Quote
Old 08-26-2013, 05:47 PM   #11
jamesm
the part # on the sensor is 'MAP-K-4BAR', two other numbers on the package are 'P0-000022227' and '032113'. hope this helps. thanks!
Old 10-02-2013, 03:22 AM   #12
RAN94A
Grand PooBah
RAN94A's Avatar
Drives: Toyota 86 GT MT
@mad_sb
would this be the same for the 3 bar AVO sensor??
http://www.avoturboworld.com/avoshop...ual-p-191.html
RAN94A is offline   Reply With Quote
Old 10-02-2013, 12:35 PM   #13
mad_sb
Originally Posted by RAN94A View Post
@mad_sb
i would imagine not, 4 bar vs 3 bar will have different scale factor for sure.
Old 10-02-2013, 12:43 PM   #14
AVOturboworld
Drives: 2013 "AVO Orange" FR-S
3 bar has different scaling than the 4 bar.
3 bar setup:
pressure (bar) offset: -0.0113
scaling: 0.629
AVOturboworld is offline   Reply With Quote
BRZedit Drive By Wire Info mad_sb Engine, Exhaust, Transmission 20 03-20-2021 01:19 PM
BRZedit E85 How-To mad_sb Engine, Exhaust, Transmission 9 04-24-2020 09:30 PM
BRZEdit (ECUEdit) illmatic Software Tuning 246 06-02-2016 01:15 PM
BRZedit Cam Tuning Info mad_sb Engine, Exhaust, Transmission 11 01-25-2015 04:58 AM
who does remote BRZedit tunes? StormTrooper Engine, Exhaust, Transmission 14 07-14-2013 04:14 PM
