Old 05-24-2018, 06:59 AM   #1
Ashleususs
Drives: GT86
Front Pipe Gasket
Hi all, I'm changing my front pipe from a catless SME to a Catted Xforce FP. However, whilst installing I noticed that there doesn't seem to be any room for the donut gasket to slot between. Do I need to use a donut gasket, or any other gaskets, or does it just bolt on? Will provide a picture of the connection between the FP and Catback bellow. Cheers
Ashleususs is offline   Reply With Quote
Old 05-24-2018, 07:12 AM   #2
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Is this front frontpipe to mid pipe (towards the back) or front pipe to overpipe (towards the front)? The donut gasket is sandwiched between the two pipe at the rear portion, going to the mid pipe. The two pipes bolted together do not 100% close the gap (in my experience anyway). You just put the donut on the front pipe and bolt it together so it is held in place.
Here's a picture of the connection http://www.ft86club.com/forums/showthread.php?t=93368
Old 05-24-2018, 07:32 AM   #3
Ashleususs
Drives: GT86
Yes, this is the connection between the Midpipe and Front pipe. My previous front pipe had a holding place for the gasket(like almost all front pipes besides my new one) to put the donut gasket between the two is almost impossible as only one of the two bolts will thread through and the donut cant physically be wedged in as a result, hence why I thought perhaps a flat gasket may be more suitable?
Old 05-24-2018, 09:28 AM   #4
cjd
cjd's Avatar
Drives: 2017 BRZ
That would call for a flat gasket.
Old 05-24-2018, 07:10 PM   #5
Ashleususs
Drives: GT86
I used a spare flat and it doesn't close off properly.
Old 05-24-2018, 08:51 PM   #6
Steve
Steve's Avatar
Drives: 6MT
Spare as in previously used? I tried to reuse a used OEM gasket on that exact connection with no luck, big leak. A fresh universal 2 bolt 2.5" gasket should do the trick.
Also, its hard to tell from your picture and it mostly likely just an illusion from the angle but the left flange looks nice and flat, but the right side doesn't look so nice a flat, even a little warped. Might be worth checking out.
Is the Xforce FP 3" in diameter? That hole on the right looks much bigger. If so, maybe a 3" gasket for that connection is more suitable? I have no experience with 3" piping leading to a 2.5".
Steve is offline   Reply With Quote
Front Pipe Install Gasket Issue? congee Engine, Exhaust, Transmission 5 07-22-2015 04:17 PM
no flange for donut gasket on J2 front pipe k0tkmnd Engine, Exhaust, Transmission 1 06-05-2015 02:04 PM
Front Pipe donut gasket EightSix93 Scion FR-S / Toyota 86 GT86 General Forum 1 06-02-2015 09:02 PM
Installing front pipe...need gasket sealant? Fizz Engine, Exhaust, Transmission 10 07-23-2014 10:40 AM
front pipe use donut gasket or not garfull Engine, Exhaust, Transmission 2 12-09-2013 03:20 PM
