Old 06-05-2015, 12:37 PM   #1
k0tkmnd
Drives: 2013 Hot Lava FR-S
no flange for donut gasket on J2 front pipe
recently got a J2 front pipe that's 2.75" and noticed that the flanges on both ends are flat. No extension for the donut gasket to fit on like I've seen on a lot of other front pipes. It just came with normal flat gaskets. Will this work ok without the donut? do I skip the spring bolts normally used and use regular nut & bolt?
This will be mated up to an Invidia Q300.
k0tkmnd is offline   Reply With Quote
Old 06-05-2015, 02:04 PM   #2
kch
Senior Misanthrope
kch's Avatar
I had an exhaust shop weld a flat flange onto my stock midpipe as a temp fix. was about $90.
Front Pipe donut gasket EightSix93 Scion FR-S / Toyota 86 GT86 General Forum 1 06-02-2015 09:02 PM
Front pipe flange warped? Fizz Engine, Exhaust, Transmission 3 12-23-2014 02:47 PM
Installing front pipe...need gasket sealant? Fizz Engine, Exhaust, Transmission 10 07-23-2014 10:40 AM
front pipe use donut gasket or not garfull Engine, Exhaust, Transmission 2 12-09-2013 03:20 PM
BRZ Donut Gasket same part as WRX STi Gasket? Zadkiel Engine, Exhaust, Transmission 0 10-06-2012 07:22 AM
