Old 12-09-2013, 02:57 PM   #1
garfull
garfull's Avatar
Drives: FRS(sold), AP2, R35, FJC, ED9
front pipe use donut gasket or not
When replacing the front pipe which is typically 2.5"od, the oem donut gasket no longer works, so what if any down sides are there to using a flat gasket to connect the front pipe to the oem axle back exhaust?
Also any downsides for not using the oem bolts which have springs on them and just hard bolting the two flanges together?
I'm assuming the oem design allows for a lot of flex in the system and by using a flat gasket and bolts that the system is now more rigid.
garfull is offline   Reply With Quote
Old 12-09-2013, 03:09 PM   #2
MAPerformance
Drives: Asphalt FRS
Which front pipe do you have? I know ours has an adapter so the doughnut gasket can still be used.
MAPerformance is offline   Reply With Quote
Old 12-09-2013, 03:20 PM   #3
jamesm
i have a j2 front pipe, which is true 2.75" through and thus does not have the step down for a donut gasket. it works just fine using a normal gasket and bolts flat to the midpipe.
Perrin front pipe + stock cat back, what gasket? wparsons Engine, Exhaust, Transmission 14 10-09-2014 07:05 AM
Installing front pipe...need gasket sealant? Fizz Engine, Exhaust, Transmission 10 07-23-2014 10:40 AM
BRZ Donut Gasket same part as WRX STi Gasket? Zadkiel Engine, Exhaust, Transmission 0 10-06-2012 07:22 AM
