Old 07-21-2015, 08:04 PM   #1
congee
congee's Avatar
Drives: SSM BRZ
Front Pipe Install Gasket Issue?
Hello,
I recently got a MXP catless front pipe installed at a new mechanic as a lot of frs/brz guys in my area recommended him. In the instructions, it says to reuse the oem donut gasket but the new mechanic said that they used a flat head gasket instead as the fitment is better? Does anyone know if its fine or should I go back to my old mechanic to get him to put in the donut gasket? He said it was fine and they didn't find any leaks but will I run into any problems in the future?
congee is offline   Reply With Quote
Old 07-22-2015, 10:06 AM   #2
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
i would use new donut gasket.
Old 07-22-2015, 12:02 PM   #3
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
donut gasket
i reused mine from the stock FP, no leaks
Old 07-22-2015, 03:33 PM   #4
congee
congee's Avatar
Drives: SSM BRZ
What should I listen for if theres an exhaust leak? So far, I haven't noticed any issues with it and ive driven about 100km
Also, on the rare occasion when I tap the gas, I hear a faint wining sound but not sure if thats the drop in filter or exhaust. It happened before I got my front pipe installed too.
Old 07-22-2015, 03:48 PM   #5
WhiteFRS69
WhiteFRS69's Avatar
normally what i do, ill make sure the car is cool before starting it.
but just start the car, and rub your hands around the area you think you have an exhaust leak, if you feel anything, than you have a leak
Old 07-22-2015, 04:17 PM   #6
DM7
Drives: '13 FR-S Argento
From what I have seen on after market catback systems is if the midpipe has a flex joint, the supplied gasket will be a flat type. If there is no flex joint in the midpipe (as is the case on the stock midpipe) a donut gasket is used. Either way, I personally would want some kind of device that allowed the header and front pipe to move independently from the midpipe.
As for your wining sound you will have to provide a lot more information or a video of the problem for us to figure out what it is.
DM7 is offline   Reply With Quote
no flange for donut gasket on J2 front pipe k0tkmnd Engine, Exhaust, Transmission 1 06-05-2015 02:04 PM
Front Pipe donut gasket EightSix93 Scion FR-S / Toyota 86 GT86 General Forum 1 06-02-2015 09:02 PM
Front pipe to mid pipe gasket? ryoma Engine, Exhaust, Transmission 6 04-30-2015 12:27 AM
Installing front pipe...need gasket sealant? Fizz Engine, Exhaust, Transmission 10 07-23-2014 10:40 AM
front pipe use donut gasket or not garfull Engine, Exhaust, Transmission 2 12-09-2013 03:20 PM
