BRZ passenger window will not pair!
What is going on my BRZ and FRS Brotheren?
I know what your thinking, this idiot just needs to pair his window by holding down the window switch for 5-10 seconds and then repeat on the way up. I know this process and have had great success with this process in the past, but after 3 months of repeated attempts, i am turning here for help. I have the typical, flashing light on the passenger window switch, window valet not working and leaving the window down after anyone opens the passenger side door. This all started when i replaced the speakers in each door. I took off both door pannels, sound deadened them, and put them both back together without issue. Thoughts: Could the rubber window seal that the window goes into when you roll it up be causing a jam? Could a screw have come loose and caused the window itself to loose it's mounting position? Any help will be greatly appreciated. Thanks guys, Balakay! |
#2 | |
| The Following User Says Thank You to Tcoat For This Useful Post: | humfrz (05-10-2018) |
I completely agree that there could be a multitude of things happening, especially since it let me pair the window once about a month ago, but it immediately jammed and stopped working the next use.
I have pulled the panel off three times now, checked all wires, and i even purchased and installed a whole new window up/down switch that helped none. I have checked to make sure the window is not touching anything, relocated all wires to be completely out of reach of the window, and still nothing. |
| The Following User Says Thank You to paintdude258 For This Useful Post: | Tcoat (05-10-2018) |
Drives: Track preped NA FRS
My driver window stopped pairing as well, but I have no blinking light. The window just doesnt move up/down when opening or closing the door. Mine is almost full on racecar by now, so I just let it be. It started happening after I had a rollbar installed, so maybe some wired got cut or moved or something, as @Tcoat suggested.
| The Following User Says Thank You to Icecreamtruk For This Useful Post: | Tcoat (05-10-2018) |
Sarcastic SOB
Toyota service?
| The Following User Says Thank You to wbradley For This Useful Post: | Tcoat (05-10-2018) |
#6 | |
| Tags |
| jam, jammed, pair, window |
| my passenger window does nothing | lucy86brz | Electronics | Audio | NAV | Infotainment | 0 | 01-25-2018 09:59 PM |
| Window Shatter / Fracture - passenger small triangular window | btune | Issues | Warranty | Recalls / TSB | 5 | 12-25-2016 02:14 PM |
| Passenger Window | Sailors14FR-S | Issues | Warranty | Recalls / TSB | 10 | 05-04-2014 10:28 PM |
| passenger window reset?? | damaster32 | Issues | Warranty | Recalls / TSB | 3 | 03-25-2014 12:00 PM |
| Passenger Window Switchs Out | LarryGP | Issues | Warranty | Recalls / TSB | 10 | 11-13-2012 06:04 PM |
