Old 11-07-2012, 06:25 PM   #1
LarryGP
LarryGP's Avatar
Drives: Asphalt FR-S MT
Passenger Window Switchs Out
I went to roll down my windows today on my FR-S and was unpleasantly surprised to find that the passenger side window wouldn't roll down. The backlights to both of the switches for the passenger side window were out and neither were responsive...
Anyone else have this problem? Could it be a fuse or loose wire in the harness?
"Think very carefully… because if you ever start, you will never be able to leave it alone."— Donald Campbell
2013 FR-S MT/Asphalt
2003 Mustang
1985 Porsche 944 Chumpcar
LarryGP is offline   Reply With Quote
Old 11-07-2012, 06:58 PM   #2
JesseE
JesseE's Avatar
Drives: LS Swapped BRZ
always check your fuses first :-)
JesseE is offline   Reply With Quote
Old 11-08-2012, 12:36 AM   #3
bakerr6
Drives: 2013 raven black fr-s
i'm having a similar issue. My pass. window wont roll down with the driver switch, but will with the pass. switch. The other annoying thing about it, is that I have to adjust it with every time I get in, because the window doesn't automatically go all the way back up
bakerr6 is offline   Reply With Quote
Old 11-08-2012, 01:04 AM   #4
ABQautoxer
ABQautoxer's Avatar
Drives: 2021 Supra / 2022 Tundra
Try this:
Put car to on, engine off. Push and hold button down until window rolls down and you hear a click. Then hold window button up until it rolls up and you hear a click.
TomR
ABQautoxer is offline   Reply With Quote
Old 11-08-2012, 07:25 AM   #5
bakerr6
I tried that ABQ, but my window wont go up or down on the passenger side with the driver's switch
Old 11-08-2012, 07:27 AM   #6
JDMenrique
DEEEERP
JDMenrique's Avatar
Take it to the dealer, the sooner the better.
JDMenrique is offline   Reply With Quote
Old 11-08-2012, 09:01 AM   #7
ABQautoxer
ABQautoxer's Avatar
On my Lexus you have to do it from each door switch itself. So in this case do this from the passenger door window switch. Door has to be closed too.
TomR
Old 11-08-2012, 11:03 AM   #8
LarryGP
LarryGP's Avatar
The child safety locks were on... apparently they also turn off the backlights of the switches...
I feel dumb now, even though the guy at the dealer said this wasn't the first time someone's done this....
2003 Mustang
Old 11-08-2012, 12:18 PM   #9
bakerr6
Worked this time thank you!
Old 11-13-2012, 02:16 PM   #10
Stu baru
Official Cobb beer knurd
Stu baru's Avatar
Drives: 2013 BRZ-L MT SWP
Originally Posted by ABQautoxer View Post
Try this:
This is the fix to the symptom, had this happen to me last week when it got below freezing after a rain. Didn't know about this fix the, so it went to the dealer. Happened again this morning under the same circumstances, but this time I did some online research and found the above.
As a side note, I called the tech at the dealer that worked on my car and he's going to contact Subaru to see what they can suggest since I identified the source of the issue for him. I inquired about either reprogramming so the windows don't drop the 1/2" when the door opens, or disconnect the door-open sensor the windows monitor, but he said the windows when fully raised sit in channel what would bind when you went to open the door with the windows fully up (and might break the window).
Don't text while driving, everyone around you will appreciate you not endangering their lives.
Stu baru is offline   Reply With Quote
Old 11-13-2012, 06:04 PM   #11
RoryTate
Drives: 2013 Subaru BRZ
Have a look:
http://www.ft86club.com/forums/showthread.php?t=20754
RoryTate is offline   Reply With Quote
Auto-Up/Down and Passenger Window Not Working chanomatik Issues | Warranty | Recalls / TSB 106 05-09-2021 01:25 AM
WTB: BRZ Limited Passenger Seat famfanfan Interior Parts (Incl. Lighting) 4 04-01-2013 11:30 PM
Passenger window mystery FRiSson Scion FR-S / Toyota 86 GT86 General Forum 6 09-07-2012 02:30 PM
Teaking Tail light and Driver side passenger window auto down feyrerm Issues | Warranty | Recalls / TSB 2 08-11-2012 12:32 AM
How FUN is it being the passenger? TeaBuoy Scion FR-S / Toyota 86 GT86 General Forum 13 06-20-2012 04:44 PM
