Old 05-04-2014, 08:11 PM   #1
Sailors14FR-S
Sailors14FR-S's Avatar
Drives: 2014 Scion FR-S
Passenger Window
Ok so all i could find was the freezing window issue... but it is hot here and not only does the window not roll down, but the window switches for that window do not light up. Fuse?
Sailors14FR-S is offline   Reply With Quote
Old 05-04-2014, 09:29 PM   #2
supramkivtt2jz
PROUD OF BOXER
Drives: Raven FR-S
did you read the manual? theres a sentence or two about it.....
supramkivtt2jz is offline   Reply With Quote
Old 05-04-2014, 09:30 PM   #3
Sailors14FR-S
Old 05-04-2014, 09:48 PM   #4
humfrz
Have you done the proceedure as shown on page 53 of the manual ... ??
That may fix er up .....
humfrz
Old 05-04-2014, 09:49 PM   #5
Sailors14FR-S
no i haven't, give me a minute and I will update everyone...
Old 05-04-2014, 09:57 PM   #6
Sailors14FR-S
nope that was not the issue, and i guess it would have helped if I told you guys that is stuck in the up position and it does do the normal movement when you open the door...
Old 05-04-2014, 10:03 PM   #7
humfrz
hmmmmm........OK, next I'd suggest you check fuse #14 (a 25 amp fuse) found in the fuse box under the hood.
First ..... make sure the window lock switch (found on the driver's side) hasn't been pushed.
come back.
humfrz
Old 05-04-2014, 10:06 PM   #8
Sailors14FR-S
Ok brb
Old 05-04-2014, 10:12 PM   #9
Sailors14FR-S
well, its not the fuse... i had already tried the lock switch, but I figured this time i would play with it... and after about ten lock/ unlocks... it works, so i guess i get to go get a new switch... thanks for all your help
Old 05-04-2014, 10:17 PM   #10
humfrz
You're quite welcome.
I've read several times here on the forum, that folks have had this situation ..... and after fiddling with the switch several times ..... it "fixed itself" .....
But, I'm always leary of things that "fix themselves".
Have a good rest of the weekend!
humfrz
Old 05-04-2014, 10:28 PM   #11
Sailors14FR-S
U too buddy thanks again
Window Shatter / Fracture - passenger small triangular window btune Issues | Warranty | Recalls / TSB 5 12-25-2016 02:14 PM
passenger window reset?? damaster32 Issues | Warranty | Recalls / TSB 3 03-25-2014 12:00 PM
passenger window issue =.= Jeong Issues | Warranty | Recalls / TSB 0 03-13-2013 08:19 PM
Passenger Window Switchs Out LarryGP Issues | Warranty | Recalls / TSB 10 11-13-2012 06:04 PM
Passenger window mystery FRiSson Scion FR-S / Toyota 86 GT86 General Forum 6 09-07-2012 02:30 PM
