Old 03-26-2018, 07:08 PM   #1
Christopher86
Drives: White Auto 86
Front Camber Bolts?
Any suggestions on these or differneces?
Looking at SPCS & Whitelines
Also I know its for the TOP Bolt, but is it possible to get 2 sets and have 2 on each side of the strut? for top and bottom to get more camber, or does it not work like that?
sorry really noob to this, please let me know!
Christopher86 is offline   Reply With Quote
Old 03-26-2018, 07:19 PM   #2
strat61caster
strat61caster's Avatar
No difference
Yes
Yes
ineedyourdiddly
Old 03-26-2018, 07:58 PM   #3
Jamestl
Drives: None
I got two sets of SPC bolts (so top and bottom). On stock suspension I got 2.7 and on Bilstein and rce tarmacs I got 3.1.
Jamestl is offline   Reply With Quote
Old 03-26-2018, 09:27 PM   #4
HSUBLU
Drives: 2017 BRZ WR Blue
I have one set of bolts on the top on left and right. Somehow I managed to get -2.4 left, -2.35 right...
HSUBLU is offline   Reply With Quote
Old 03-27-2018, 07:47 AM   #5
Christopher86
some people say they couldnt fit the bolts on the bottom part?
is the part number 81305 for the bolts? i want 2 sets like you but just wanted to make sure!
Old 03-27-2018, 12:03 PM   #6
Jamestl
Drives: None
It's the exact same parts. I can tell you for sure they both fit (I swapped out my stock suspension for hte bilstein/RCE combo myself). How easy it is to align is not something i can answer but take it to any performance shop and i'm sure they'd know what to do.
Old 03-27-2018, 12:29 PM   #7
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
81305 is 14mm and would be too small for the top hole. It is meant for the bottom slot. While you could get more adjustment since it's got extra play there have been issues of slippage with slotted struts and eccentric bolts so not sure that would be a good idea.
Get the 16mm SPC bolt for the top if you want to run 2 eccentrics. Or get 81305 for the bottom and put the OEM bottom bolt in the top to get more adjustment.
I'll see if I can find the 16mm SPC part number and update my adjustable suspension FAQ and link back here later.
Edit: http://www.ft86club.com/forums/showthread.php?t=103609 has the part numbers for both the 14mm and 16mm SPC bolts in the first post now
Christopher86 (03-29-2018)
Old 03-27-2018, 01:12 PM   #8
strat61caster
81280 - 16mm
81260 - 14mm alternative
ineedyourdiddly
Old 03-27-2018, 01:21 PM   #9
finch1750
finch1750's Avatar
81280 - 16mm
What's the difference between 81260 and 81305?
Old 03-27-2018, 01:24 PM   #10
8RZ
The Gunshine State
8RZ's Avatar
Drives: '14 BRZ Limited
The difference is 45.
Current DD: M235i
8RZ is offline   Reply With Quote
The Following 4 Users Say Thank You to 8RZ For This Useful Post:
finch1750 (03-27-2018), Impureclient (04-01-2018), new2subaru (03-31-2018), Spacemane969 (03-31-2018)
Old 03-27-2018, 01:34 PM   #11
strat61caster
beats me, I've had the 81260 installed on my car for three months so there's that
the description on the spc website is more detailed on the 81260 than the 81305 fwiw
ineedyourdiddly
Old 03-27-2018, 01:45 PM   #12
finch1750
finch1750's Avatar
But 81305 says its specific for the FRS/BRZ. I wonder if they just create new part numbers for certain cars so it comes up in Google searches
strat61caster (03-27-2018)
Old 03-31-2018, 03:56 PM   #13
Jamestl
Drives: None
I just checked my part numbers and I have two of the 81305 sets. Have had them for about a year with no issues. Where have you seen issues of slippage?
Old 03-31-2018, 04:54 PM   #14
EAGLE5
Dismember
EAGLE5's Avatar
Drives: 2013 Red Scion FR-S
Slippage happens. If you're doing top and bottom bolts, just check for it every once in a while. It's not like the whole suspension is going to fall off.
OEM front camber bolts B-R-Z Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 04-30-2014 08:05 PM
WTB Front Camber bolts manualmotive Want-To-Buy Requests 2 04-17-2014 02:45 AM
Front Camber Bolts option hanabie Suspension | Chassis | Brakes -- Sponsored by 949 Racing 8 11-10-2013 12:28 AM
*FREE alignment* When you get Front Camber Bolts and Rear Camber Arms Installed! Corner3garage Mechanical Maintenance and Tools 6 10-31-2013 03:40 PM
