Old 11-07-2013, 04:23 PM   #1
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
Front Camber Bolts option
Does anyone know the part number for OEM camber bolts?
What's the maximum setting? What other good options beside OEM camber bolts?
Thank you much
hanabie is offline   Reply With Quote
Old 11-07-2013, 08:59 PM   #2
Fizz
Senior Addict
Fizz's Avatar
Drives: 86 GT
OEM upper camber bolt: SU003-02805
Another option is Whiteline upper camber bolt: KCA416 (or SPC 81280)
I believe both would give you approx -1.3 or thereabouts?
Fizz is offline   Reply With Quote
The Following 2 Users Say Thank You to Fizz For This Useful Post:
hanabie (11-07-2013), whataboutbob (11-10-2013)
Old 11-07-2013, 11:18 PM   #3
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
SPC 81280 and/or 81260. I run both.
Intent > Content
Old 11-08-2013, 01:27 AM   #4
hanabie
hanabie's Avatar
two bolts per side or just one bolt? thanks
Old 11-08-2013, 04:07 PM   #5
solidONE
solidONE's Avatar
Both sets. 2 on each side. 4 bolts replaced total.
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
hanabie (11-08-2013)
Old 11-08-2013, 09:27 PM   #6
hanabie
hanabie's Avatar
Why running both? I thought lower hole gives more neg camber per manual statement. Are you looking for more camber? How many neg camber can u get? Thanks. Spc bolts apparently are significantly cheaper than whiteline.
Sent from my SGH-T999 using Tapatalk
Old 11-08-2013, 10:42 PM   #7
solidONE
solidONE's Avatar
Whiteline bolts are reboxed SPC bolts. They will have SPC logo cast into the bolt heads. Yes I was looking for as close to -3* of camber as I could without camber plates. I got -2.6* with the bolts. Although if you had to pick one to use the upper 16mm bolts would be a safer bet as they are a thicker diameter thus stronger. Also, my 81280 SPC bolts were zinc coated as well. Some that got the whiteline bolts did not have zinc plating and reported corrosion.
Intent > Content
Old 11-09-2013, 10:27 PM   #8
hanabie
hanabie's Avatar
I got the silver ones from amazon. Looks like those are the new ones.
Old 11-10-2013, 12:28 AM   #9
whataboutbob
AutoX-10/10ths every run
Whiteline ones gave me -1 3/8.
Build thread:Here
Softening coils. Chen Northwest 3 10-29-2013 03:36 PM
Anyone running HSD coils?? PB-GT86 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 2 09-01-2013 10:21 AM
Used set of BC coils for sale Astra^EC AFRICA 0 08-22-2013 09:55 AM
Need help picking coils WolfsFang Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 03-11-2013 09:31 PM
Coils vs Coilovers trish07 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 08-17-2012 10:41 AM
