Old 03-06-2018, 12:27 PM   #1
Dr.Spocktagon
Drives: 2013 Asphault FRS
Can I replace the front crossmember
In my 2013 FRS I jumped a median this morning at 8:00 trying to navigate to an off ramp that’s in the center of a busy four lane. I didn’t make it. Looks like the cross member is bent and the skid plate, and the hood won’t shut. I’d like to do most of the work myself, then take it to an alignment specialist. Is this doable?
Last edited by Dr.Spocktagon; 03-06-2018 at 06:39 PM. Reason: Added year and model of car
Dr.Spocktagon is offline   Reply With Quote
Old 03-06-2018, 01:54 PM   #2
wparsons
wparsons's Avatar
If the hood won't shut right, there's probably more bent than just the crossmember and skid plate... I'd bet you've bent the rad support, or even the front frame rails themselves.
I'd get it looked at by a pro first, then decide if you want to take on the work.
flickr
The Following 2 Users Say Thank You to wparsons For This Useful Post:
Leonardo (03-06-2018), strat61caster (03-06-2018)
Old 03-06-2018, 02:59 PM   #3
Dr.Spocktagon
Thank you. It does look like that.
Old 03-06-2018, 06:29 PM   #4
Dr.Spocktagon
I took it to a couple shops this afternoon. The radiator support is pushed up just a tad. The first shop offered to “bend it back” with a “frame bender.” Looks like I’m going to research replacing the damaged parts of the radiator support myself. I’ll also put an aftermarket header on at some point since the stock shroud is bent. The crossmember was fine. I was looking at the radiator support thinking it was the crossmember. So, I’ll take the bumper off, take the bent support parts off, check out the radiator and compressor, and see where I’m at. I’ll be looking for info while I’m taking it apart.
Old 03-06-2018, 08:50 PM   #5
nocoolname
You'll need a spot weld cutter and welder to replace what's bent, and that's just the beginning, you'll need the factory measurements to make sure it's all square before spot welding, you'll have to paint the replacement pieces and welded areas and so on. This isn't a DIY thing.
2001 MR-S - long, slow, rebuild
2000 MR-S - 2zz swapped daily
2013 BRZ limited - new toy
nocoolname is offline   Reply With Quote
The Following User Says Thank You to nocoolname For This Useful Post:
wparsons (03-07-2018)
Old 03-06-2018, 09:11 PM   #6
Dr.Spocktagon
That’s very helpful. I have a welder machinist friend who seems interested. If we’re going to do it I’ll have to look for those measurements. Thank you. I’ll report back if I make any progress.
Old 03-07-2018, 04:29 PM   #7
wparsons
wparsons's Avatar
Welding is the easy part, it's making sure the car is straight before welding it back in place that's the hard part. It'll need to be on a frame machine to determine this, which means a good shop.
flickr
Old 03-07-2018, 05:28 PM   #8
GrantedTaken
[ame="https://www.youtube.com/watch?v=JAfzPHA_QcY"]BRZ Resurrection Part 1 - Where it all started... or didnt. - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=H4BOHfbVPqQ&t=364s"]BRZ Resurrection Part 2 - Hood, Fenders, And Core Support - YouTube[/ame]
GrantedTaken is offline   Reply With Quote
Old 03-08-2018, 04:57 PM   #9
Dr.Spocktagon
Those videos are great. I decided to get a really good shop to do it. I want it to be right. Now I need to figure out what to upgrade while it’s taken apart. I’m definitely replacing the header.
The Following 2 Users Say Thank You to Dr.Spocktagon For This Useful Post:
strat61caster (03-08-2018), VIP BRZ (03-08-2018)
Have to replace entire assembly to replace fuel filter? tobkin Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 20 08-04-2017 03:26 PM
How To Replace Front Quarter Panel? HueyLooie Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 7 05-31-2015 03:50 AM
AVO Transmission Crossmember Bushing Install Pix Infamous Performance DIY (Do-It-Yourself) Guides 0 09-29-2014 04:48 PM
Replace front DRL/indicators on GT/FRS 2SeeKU Cosmetic Modification (Interior/Exterior/Lighting) 11 11-29-2013 10:38 PM
replace front crash bolts to add camber? Matt Andrews Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 06-15-2012 11:05 AM
