Old 11-28-2013, 01:07 AM   #1
2SeeKU
Drives: Raven GT86 & Subaru WRX CS6
Replace front DRL/indicators on GT/FRS
Hey Guys,
I've fitted BRZ headlights to my GT and was wondering if there was something l could replace the DRL/indicator with on the front bar with?
As the BRZ headlights already have an indicator, l don't really need the two!
Cheers!
2SeeKU is offline   Reply With Quote
Old 11-28-2013, 02:11 AM   #2
RZ86
RZ86's Avatar
Drives: 2012 Toyota GT 86 Manual
Look at what Kalen (JET86) in NSW has done to his. Looks much better with the fog/indicator delete.
Current: '12 Toyota GT 86 Pearl White Manual
Previous: '96 Toyota Supra SZ-R
RZ86 is offline   Reply With Quote
Old 11-28-2013, 02:23 AM   #3
2SeeKU
Cheers
Not sure if that would suit my car...
Old 11-28-2013, 03:01 AM   #4
s2d4
s2d4's Avatar
Originally Posted by 2SeeKU View Post
Hey Guys,
Cheers!
How did you wire up the indicators to the BRZ headlights?
Did you just pull it off the front indicators on the bumper then plug it directly into the indicators on the BRZ headlights?
Old 11-28-2013, 03:25 AM   #5
2SeeKU
Pretty much. The BRZ headlights use an 8 pin connector(GT/FRS uses 6 pin), with an extra wire used for the indicators. I simply taped the existing indicator positive line and plugged it into Pin 1 (diagram attached).
Old 11-28-2013, 03:45 AM   #6
s2d4
s2d4's Avatar
Yeap, I have a gts and have brz headlights in my lounge but haven't taken off the bumper to check yet.
Not keen on modifying the harness so I am just trying to figure out if I need to make a loom for it.
Old 11-28-2013, 07:12 AM   #7
s2d4
s2d4's Avatar
btw, have you looked at the camry front? it might just fit to cover the holes
Old 11-28-2013, 07:12 AM   #8
2SeeKU
Its very simple to repin the harness though. Took me maybe 5 minutes as a first timer.
The GT actually has the wires in matching colours (i.e right parkers are both red). This made the job much easier for me. I can't help you with the GTS but if you have any question about the BRZ wiring, let me know.
Actually, what are you going to do about the auto leveling? BRZ uses the same harness as the GT. I think the GTS maybe different...
Old 11-28-2013, 07:19 AM   #9
s2d4
s2d4's Avatar
It also uses 8 pins, everything is the same except for pin 1 (not used in GTS) and pin 2 (high LED on GTS)
As for auto leveling, I hadn't looked into it yet. I don't see why it would be different but I'll know when I take the bumper off, unless someone can chime in.
EDIT:Just checked, same plug.
Old 11-29-2013, 06:45 PM   #10
86ing
Drives: Red 86
how much did you get them for? :O
86ing is offline   Reply With Quote
Old 11-29-2013, 09:16 PM   #11
s2d4
s2d4's Avatar
2k from Japan. Oz Stealerships wants close to 5k after GST...
Old 11-29-2013, 09:38 PM   #12
Fett4Real
AKA Mugen Dom
Fett4Real's Avatar
Drives: 2013 FR-S, 2007 FJ Voodoo Blue
Love them wheels
Fett4Real is offline   Reply With Quote
Better Mic to replace OEM Mic in BRZ / FRS ??? Zgrinch Electronics | Audio | NAV | Infotainment 42 02-06-2015 01:19 AM
Single tap indicators sav AFRICA 6 05-28-2013 01:24 PM
Side Mirror Indicators DriftEightSix Cosmetic Modification (Interior/Exterior/Lighting) 2 03-24-2013 12:37 AM
Looking to replace my sedan carbonBLUE Other Vehicles & General Automotive Discussions 5 01-11-2013 08:41 PM
replace front crash bolts to add camber? Matt Andrews Suspension | Chassis | Brakes -- Sponsored by 949 Racing 15 06-15-2012 10:05 AM
