Old 05-27-2015, 03:41 AM   #1
HueyLooie
Drives: Scion
Unhappy How To Replace Front Quarter Panel?
I need help on how to remove the front quarter panel on the passenger's side.. Looking to replace it. It is damaged beyond repair. No one on these forums seems to have had this issue thus far!
HueyLooie is offline   Reply With Quote
Old 05-27-2015, 06:46 AM   #2
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
Front fender?
Remove bumper.
Remove fender lining.
Remove bolts on on top of fender in the engine bay. Remove bolts underneath connecting fender to the chassis. Pull off fender garnish and remove bolts by opening door to reach them. Remove last bolts near the headlight. Remove bumper mounting tabs from damaged fender and place onto replacement fender.
Install new fender. Install front bumper and corner lights. Install fender lining.
Done.
There are DIYs on the forum that walk you through various parts, like the bumper removal DIY. It's actually quite easy and self explanatory when you get into it.
TylerLieberman is offline   Reply With Quote
Old 05-27-2015, 09:48 PM   #3
HueyLooie
Drives: Scion
Originally Posted by TylerLieberman View Post
Front fender?
Remove bumper.
Done.
This is great. So i wont have to take my wheel off after all it seems?
Old 05-27-2015, 10:22 PM   #4
projek_01
projek_01's Avatar
Drives: 1996 ST204, Series 10 FR-S
You need a stubby screw driver to reach the fender liner clips if you are still at stocker height. If you are lowered, take the wheel off for sure. Personally, I'd jack it up anyways since there are 10mm bolts at the bottom of the car.
projek_01 is offline   Reply With Quote
Old 05-27-2015, 10:31 PM   #5
TylerLieberman
Drives: '24 GR86
You don't have to take it off but you might find it easier with the wheel off as it gives you more room to work.
Old 05-28-2015, 10:48 AM   #6
jshadeck
jshadeck's Avatar
Drives: 2013 Scion FR-S Whiteout 6MT
Im lowered, i removed the fenders and liners, mocked up/installed vf fenders, measured trimmed liners and reinstalled all w the wheels on the car. Definitely not a problem if you jack the car up (which you have to do to remove the wheel anyways) but yes it would give you more room, u just dont need it.
Theres definitely writeups on this process though, make sure u search for "fender" not "front 1/4 panel". As stated theres bolts on the top under the hood, one under the vent/garnish piece near mirror, underneath the car behind the wheel on the rollpan area, bumper has to come off, and headlight (if i remember correctly, they definitely had to come off for me to do the vf fenders)
jshadeck is offline   Reply With Quote
Old 05-30-2015, 06:00 PM   #7
HueyLooie
Drives: Scion
Thanks to everyone. This is really good input. Some of you mentioned to remove the fender garnish to get to the bolt that's supposedly behind it.. How do I get that to pop off without breaking it? I feel like I'm doing it wrong.
Old 05-31-2015, 02:50 AM   #8
jshadeck
jshadeck's Avatar
Theres a piece of 3m adhesive near the back edge (closest to mirror) and a bunch of clips. If u open the hood and look in behind the trim piece you can see a few, other than the 3m it just pulls off, u can heat up the 3m a little or use a piece of fishing line behind it
Rear quarter panel replacement sero901 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 5 09-25-2015 12:41 PM
Quarter Panel Dent repair FerraraZ Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 4 06-04-2014 11:34 AM
Can someone ID this quarter panel? JordanWho Cosmetic Modification (Interior/Exterior/Lighting) 7 01-14-2014 06:09 AM
WTB FR-S RIGHT REAR QUARTER PANEL Billylammerkins Exterior Parts (Aero, Lighting, Etc.) 7 01-01-2014 10:21 PM
[AUS] Quarter Panel Repair mswhong Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 2 07-27-2013 11:02 PM
