Old 06-13-2012, 04:46 PM   #1
Matt Andrews
Matt Andrews's Avatar
Drives: race cars
replace front crash bolts to add camber?
Has anyone actually replaced their front crash bolts with the subaru part in order to dial in more front camber?
I just ordered 2 sets of bolts and should have them by the weekend. I'll be test fitting them and brake pads beginning of next week.
Just curious if anyone has actually done this to see what the adjustment is.
FYI - the part # is 901000394
Matt
11/19/12 - Just back from Redline TimeAttack's demo event. Video and write up in link below.
http://fecompetition.wordpress.com/
https://www.facebook.com/FECompetition
Matt Andrews is offline   Reply With Quote
Old 06-13-2012, 04:46 PM   #2
MTeator
First 86
Mine have been on backorder from the dealer for two weeks.
Scion First 86 in Lexington KY - Firestorm 6MT - Delivered May 17, 2012
Mods: Motegi 17x7 TrakLites, BFG Rivals, K&N 33-2300 Filter, Nameless Perf. Track Pipe, TRD springs & rear bar, Hotchkis front bar (eh), Kask trailer hitch
MTeator is offline   Reply With Quote
Old 06-13-2012, 04:49 PM   #3
Racecomp Engineering
Yes, we have them on our car along with Whiteline Com-C top mounts. Check our facebook or this post:
http://www.ft86club.com/forums/showp...7&postcount=26
- Andrew
Old 06-13-2012, 09:59 PM   #4
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
Yep: http://www.ft86club.com/forums/showp...8&postcount=75
jdrxb9 is offline   Reply With Quote
Old 06-13-2012, 10:48 PM   #5
taosracer
Frickin' Genius
taosracer's Avatar
Drives: GBS BRZ 6sp, 2002 ts wagon WRX swap
Yep, put mine in yesterday. There is a negligible increase in -camber. I wasn't able to get it on the alignment rack to measure it, but based on the #s posted by jdrxb9 and the slight amount of visible movement with them, I think they're only gaining .2-.3 degrees. I'll be putting adjustable plates on mine soon enough, and the bolts will be usefull in finely adjusting the camber to get zero cross numbers. Lots more info here: http://www.ft86club.com/forums/showthread.php?t=7918
Cullen
I hear on occasion, people say that they are bored...wrong answer....An engine can be bored, a person would more correctly state that they are boring.
taosracer is offline   Reply With Quote
Old 06-13-2012, 11:34 PM   #6
jamal
jamal's Avatar
Drives: Legacy GT
I think that you have the wrong bolts given all the camber RCE is seeing.
jamal is offline   Reply With Quote
Old 06-13-2012, 11:46 PM   #7
taosracer
Frickin' Genius
taosracer's Avatar
Read man, read
RCE is using lowering springs and Whiteline Com-C strut mounts.
BTW the part # listed by the OP is for the regular bolt (bottom of strut) not the concentric (adjusting) one.
Cullen
Old 06-13-2012, 11:55 PM   #8
jamal
jamal's Avatar
Drives: Legacy GT
Speaking of reading, did you check out post #4?
There is no "concentric" adjusting bolt for this car, just an undersized one. And you would want to say cammed or non-concentric, right?
Using the stock WRX upper front camber bolt isn't going to work because the clevis of the strut isn't cut properly for it.
Old 06-14-2012, 02:34 AM   #9
Matt Andrews
Drives: race cars
so jamal, I assume the part number you gave me is still right, yes?
thats whats showing up friday atleast.
Old 06-14-2012, 03:29 AM   #10
jamal
jamal's Avatar
Drives: Legacy GT
It should be. I got it from RCE.
Old 06-14-2012, 10:28 AM   #11
jdrxb9
jdrxb9's Avatar
Originally Posted by taosracer View Post
Read man, read
taos - I also think you have the wrong bolts if your intent is to adjust the camber per the manual and/or stay legal for SCCA stock category.
As you quoted in your other post, the manual states:
Replace the upper mounting bolt of the shock absorber ASSY FR and knuckle with a replacement bolt. (Part No.: Flange bolt 14×60 (901000394))
The replacement camber adjustment bolt is just a plain M14x60 partially threaded bolt. It is exactly the same part that is used in the lower position. It is not eccentric. It only provides adjustability by giving you extra 'slop' in the connection. If you are using a bolt that is larger in diameter than an M14 or has an eccentric lobe, I'm not surprised that you are not seeing much adjustability.
Hope this helps.
Old 06-14-2012, 04:47 PM   #12
UncleFester
Do Toyota and Subaru dealerships carry this part?
UncleFester is offline   Reply With Quote
Old 06-14-2012, 05:38 PM   #13
ultra
Curious cat.
ultra's Avatar
Drives: 86 GT base M/T - Red
Can someone provide a hookup for eccentric bolts that fit, for those who could care less about the SCCA?
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold)
1991 Mazda MX5 Miata (sold)
2007 Mitsubishi Evo 9 RS (sold)
2006 VW Golf R32 (sold)
ultra is offline   Reply With Quote
Old 06-14-2012, 05:41 PM   #14
Subaru dealerships do.
We can get them as well. We plan on having them in the box with our RCE Yellow springs if the user doesn't have them already.
- Andrew
BRZ front camber adjustment confirmed sparks Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 03-28-2013 10:17 PM
How hard to replace BRZ Nav with aftermarket Nav? eikond Electronics | Audio | NAV | Infotainment 9 05-28-2012 07:52 PM
replace the Ford Navigation system? megancheung Electronics | Audio | NAV | Infotainment 1 03-22-2012 02:51 AM
Replace stock hubs with different bolt patern ones? ahausheer Other Vehicles & General Automotive Discussions 10 02-07-2012 12:24 AM
Handling: Camber Attainable with Struts. Your Experiences? skeeler Suspension | Chassis | Brakes -- Sponsored by 949 Racing 31 11-09-2011 04:07 PM
