Old 03-06-2018, 04:54 AM   #1
stlgrym3
Drives: 2017 Subaru BRZ Limited
ways to up the engine output without going FI
i'm looking for modest power gain, like about <10 hp and lb-ft gain. so far i have Greddy SP catback exhaust and TRD air filter. what else i can get to get more power out of our car without going FI?
stlgrym3 is offline   Reply With Quote
The Following User Says Thank You to stlgrym3 For This Useful Post:
Sunrise161 (03-06-2018)
Old 03-06-2018, 05:02 AM   #2
Boomerang
86
Boomerang's Avatar
EL or UEL exhaust manifold and tune
E85 good for even more HP and torque
Lots of info on this site
Old 03-06-2018, 05:13 AM   #3
churchx
churchx's Avatar
Drives: 2014 GT86
Also lowering weight. For just <10hp to your already upgraded airfilter i'd add whichever ecu tuning, OFT or Ecutek. And maybe E85.
If want more, then go for aftermarket header, cat deletes and such, +tune for them of course.
The Following User Says Thank You to churchx For This Useful Post:
nikitopo (03-06-2018)
Old 03-06-2018, 05:30 AM   #4
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
http://www.ft86club.com/forums/showthread.php?t=81493
read this. All of it
The Following 5 Users Say Thank You to guybo For This Useful Post:
gutbuster (03-08-2018), new2subaru (03-06-2018), Spuds (03-06-2018), Tcoat (03-06-2018), why? (03-06-2018)
Old 03-06-2018, 09:25 AM   #5
Tune. Even at stock setup a tune is your best bang for the buck. Also gives you the ability to change as you add parts. The stock tune is intended to meet emission and mileage requirements. This can only happen by sacrificing performance.
gtengr (03-06-2018), nikitopo (03-06-2018)
Old 03-06-2018, 09:43 AM   #6
bfrank1972
Drives: 2013 FR-S Argento
As others have said, main ingredients are a proven/quality long tube header + good tune. After that I'd say manifold spacers (Crawford blocks, need to tune for these), and then maybe 4.56 final drive. If E85 is readily available, add that to the mix. Everything else (intake, OP, FP, exhaust) will provide marginal gains (but dramatically increased volumes).
bfrank1972 is offline   Reply With Quote
Old 03-06-2018, 10:17 AM   #7
churchx
churchx's Avatar
Drives: 2014 GT86
imho many have overlooked "for modest power gain, like about <10 hp and lb-ft gain" bit. At no point there was question of max NA gains with bolt-on mods. And seeing modest wish i somewhat guess that non-mentioned budget might be low.
Tcoat (03-06-2018)
Old 03-06-2018, 10:33 AM   #8
I didn't miss it. Start with a tune and build as budget and desire increases. So many want to start bolting parts onto the car in the belief they are gaining power but then leave the tune right out of the equation. You can have all the air you want flowing in and back out but if running a stock tune you can not take advantage of any of it since the car can only adjust within the design parameters.
86kahl (03-06-2018), nikitopo (03-06-2018), Tristor (03-06-2018)
Old 03-06-2018, 12:11 PM   #9
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
Also, if you start with an unlocked ots tune, I can assure you it will give you hours of entertainment working on getting it running just the way you like it, with no further monetary input.
Old 03-06-2018, 12:38 PM   #10
bfrank1972
True - but caveat - if you're eventually going to go the 'ideal' route (which I haven't done yet lol), you're going to want custom tunes instead of off-the-shelf tunes. In that case, you're going to pay every time you make a significant change - might be better off doing the header+tune together first.
Also keep in mind, what you spend can vary a lot. Buy used if on a budget:
Good quality used header: $450
OFT: $400
That right there, using canned tunes, will get you pretty darned far.
The Following 2 Users Say Thank You to bfrank1972 For This Useful Post:
DAEMANO (03-06-2018), Tcoat (03-06-2018)
Old 03-06-2018, 12:51 PM   #11
OFT: $400
There are hundreds of possible variations on the theme but if only looking for a few HP bump a good jumping off point is a canned tune. If buying one of the more advanced tuning options then they can build custom ones right on it. Anybody asking this basic a question is probably not ready to go into custom tunes just yet anyway.
bfrank1972 (03-06-2018), nikitopo (03-06-2018)
Old 03-06-2018, 01:03 PM   #12
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Stickers
The Following 6 Users Say Thank You to finch1750 For This Useful Post:
86kahl (03-06-2018), Captain Snooze (03-08-2018), Leonardo (03-06-2018), NoHaveMSG (03-06-2018), Tcoat (03-06-2018), x808drifter (03-06-2018)
Old 03-06-2018, 01:25 PM   #13
Grady
Grady's Avatar
Oh ya those vents you put on your front fenders. Those are good for about 3hp each.
But seriously start with a tune. That will be the building block for any mods later on so it will not be a waste of money.
Old 03-06-2018, 01:51 PM   #14
nikitopo
nikitopo's Avatar
Drives: '15 BRZ RA
As others said, start with a canned tune.
High Output Alternator bear89103 Electronics | Audio | NAV | Infotainment 12 06-09-2017 04:37 PM
Line output converter help the_butcher Electronics | Audio | NAV | Infotainment 4 10-21-2016 03:32 PM
Output shaft bearing mhiscott Engine, Exhaust, Transmission 10 08-09-2016 07:04 PM
power output oft tunes denso Software Tuning 3 09-15-2015 07:53 AM
pt546-00140 Sub Output dgerny Electronics | Audio | NAV | Infotainment 1 01-09-2014 02:56 AM
