Old 09-14-2015, 05:16 PM   #1
denso
Drives: 86
power output oft tunes
Hi, how much hp will be gained if running oft stage2 EL maps w/ catless header and w/ 102ROZ?
denso is offline   Reply With Quote
Old 09-14-2015, 05:29 PM   #2
cdq85
cdq85's Avatar
Drives: 2013 Raven FR-S
1 million snail power....
or roughly 185-200 whp depending on header choice. I have no clue what the hell 102ROZ is though.
cdq85 is offline   Reply With Quote
Old 09-14-2015, 05:46 PM   #3
kch
Senior Misanthrope
kch's Avatar
Depends on the dyno, the weather, the current stomach contents of Angela Merkel, etc. It's difficult to answer that question.
What I can tell you is that my car, with OFT stg2 UEL E85, measured 204whp/162wtq in very hot weather. The dyno I used measures a stock 86 at around 170whp, so I gained roughly 34whp. I'm not sure how E85 compares to 102roz.
Old 09-15-2015, 06:53 AM   #4
golfyankee2121
Always Moving Forward
golfyankee2121's Avatar
Drives: 2013 Argento Scion FR-S
So many different variables at play here. EL headers will give you a little more top end HP than UEL headers, but not as much low end torque. You're looking at 20-40 HP gain over stock depending on header, other exhaust components, fuel quality, how well the OTS tune plays with your car, weather, etc.. I can tell you that I just went from OFT OTS Stg. 1 to Stg. 2 after my catless UEL header install and the difference is noticeable for sure. Pulls much harder than stock. Regardless of what you do, don't expect more than ~205-210 WHP. I think that's about the most anyone on here has got out of this car NA. You will have to go FI for anything more.
Hope this helps.
-J.B.
golfyankee2121 is offline   Reply With Quote
Any output on M7 T-Titan or MXP Catback Simon99 Engine, Exhaust, Transmission 10 09-13-2015 03:22 PM
Subwoofer output for Bespoke Premium bebopblues Electronics | Audio | NAV | Infotainment 5 11-29-2014 03:27 AM
pt546-00140 Sub Output dgerny Electronics | Audio | NAV | Infotainment 1 01-09-2014 01:56 AM
N/A power output potential as race setup? rice_classic Engine, Exhaust, Transmission 67 12-17-2013 07:03 PM
Interesting Findings about BRZ Audio Output Chad_W Electronics | Audio | NAV | Infotainment 14 05-03-2013 08:28 PM
