Old 04-19-2016, 07:19 PM   #1
bear89103
Old Fart
bear89103's Avatar
High Output Alternator
Does anyone know a good high output alternator for the FRS? I need to change out my alternator because I need more draw.
Project Panda86 Journal -
bear89103 is offline   Reply With Quote
Old 04-19-2016, 07:27 PM   #2
DAEMANO
Time Traveller
Damn!
The stock alternator is rated to output 130 Amps. I've electronically supercharged my car for the past 2 years on that without issue. What do you plan running? A server farm?
Seriously though, check this thread for some potential leads.
http://www.ft86club.com/forums/showthread.php?t=29850
Old 04-19-2016, 07:36 PM   #3
bear89103
Old Fart
bear89103's Avatar
Originally Posted by DAEMANO View Post
Damn!
LOL! I'm needing to run a second battery and put all the other components onto that second battery. somewhere I'm getting signal interference. Whenever I have my air suspension compressor, full audio, the neo-prism lights, all the engine bay and other show lighting, dash cam, gauges, radar detector, etc. all on... my AFR and Fuel trims bounce up and down like its on a trampoline. We tested taking all the draw off of it except for the main and boom all of a sudden, AFR and fuel trims are normal and consistent.
So putting a second battery should isolate those away from the engine. I just need to upgrade the alternator to make sure it's outputting high enough to run both.
Old 04-19-2016, 07:46 PM   #4
DAEMANO
Time Traveller
Yep, server farm. Holy crap man, that must look like the 86 version of Robot Restaurant in Shinjuku Kabukicho.
Haha ok, well just so you know. The OEM alternator is currently recharging these 3 batteries in my car on a pretty much constant basis without a problem. 2x Big Crank ETX16 & 1x Odyssey PC680.
Give it a shot, it might just work for you too depending on whatever your setup is.
Old 04-19-2016, 10:27 PM   #5
bear89103
Old Fart
bear89103's Avatar
Thank you so much! And yeah lol it is a server farm. LOL.
Old 04-19-2016, 10:30 PM   #6
Ultramaroon
not playing cards
Ultramaroon's Avatar
I bet it's your compressor motor.
Old 04-20-2016, 01:53 AM   #7
bear89103
Old Fart
bear89103's Avatar
Could be. Right now I've been driving two days with just the compressor and main attached to the battery and it seems to be ok. AFR and fuel trim a little higher than with just the main. But it's at least stable and not jumping up and down.
Old 04-20-2016, 01:56 AM   #8
Ultramaroon
not playing cards
Is that with it running? DC motors throw a LOT of electrical noise.
Old 04-20-2016, 01:57 AM   #9
bear89103
Old Fart
bear89103's Avatar
Yes. That's with it running.
Old 04-20-2016, 02:08 AM   #10
Ultramaroon
not playing cards
Damn. Guess I'm no help.
Old 04-20-2016, 11:30 AM   #11
bear89103
Old Fart
bear89103's Avatar
LOL no worries. And I will take any of the help possible. Even if it's to chase down things I've already done. That helps me to think through all the possible issues. Thank you!
Old 06-09-2017, 01:50 PM   #12
palanza87
Drives: 06 Ford Mustang
hey bumping this - did anyone ever find a solution?
palanza87 is offline   Reply With Quote
Old 06-09-2017, 03:37 PM   #13
stevesnj
stevesnj's Avatar
If you have a bad or insufficient ground connection that would reduce draw.
My 2016 Build thread
power output oft tunes denso Software Tuning 3 09-15-2015 06:53 AM
Any output on M7 T-Titan or MXP Catback Simon99 Engine, Exhaust, Transmission 10 09-13-2015 03:22 PM
Subwoofer output for Bespoke Premium bebopblues Electronics | Audio | NAV | Infotainment 5 11-29-2014 03:27 AM
pt546-00140 Sub Output dgerny Electronics | Audio | NAV | Infotainment 1 01-09-2014 01:56 AM
Interesting Findings about BRZ Audio Output Chad_W Electronics | Audio | NAV | Infotainment 14 05-03-2013 08:28 PM
