Drives: Subaru BRZ (soon?)
Clunking doring engine aceleration/deaceleration
Hello
Since Imported and fixed my car (from Copart, it had front collision) I noticed that i have clunking sound when engine is switching between driving and been driven (supplying torque to wheels, and wheels transferring torque to engine for braking) Is in normal in BRZ/GT86 or do i have some problem ? I know that my transmission holder was damaged doe to forces at the crash, i change that, but engine mounts was looking normal. I did not noticed free movement in my driveshaft. Advice? |
Mine clunks going into first and second. With only 33k miles, I figured it may be normal.
Drives: 2014 GT86
Diff movement?
not playing cards
May also be a bushing on one of the rear suspension links.
Drives: 2013 Asphalt FRS
u-joint, backlash, motor mount, suspension bushing or could be completely normal
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
| The Following User Says Thank You to FRS Justin For This Useful Post: | Tcoat (03-02-2018) |
Manual transmission or automatic?
Where does it sound liked the clunking is coming from? humfrz |
#7 | |
Its hard to say from where. It's like where is slack between motor and wheels, so it has backlash, that cause this behavior. I don't know is it normal or not. It can be so many things in the system, while i know that my suspension is rock solid, i just get my car checked.so no movements in the joins. It is impossible to make gears without a backlash just question how low that is from factory. As example, if you are on low incline, and you release clutch ( no gas pedal), car can stat jerking because of this slack, off course it not a problem since I am solving this with clutch application, just wondering should i be concern or not. |
#8 | |
However, since you have covered that, I would guess that you either have a rear axle joint that is bad or a rear axle nut that needs to be tightened. Those are my best guesses for the day ...... ![]() humfrz |
not playing cards
The loose axle nut makes a glassy, high-pitched 'tink' sound.
| The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (03-02-2018) |
#10 |
get a video of it and post it
#11 |
https://vocaroo.com/i/s1QQNzjjcTVx
It is best hear from 24s mark. I just want to know is it normal. It was in first gear stooping starting car, so torque is transferred back and fourth between engine and wheels. Does your sound the same ? |
#12 |
Drives: Crapcan
Hard to tell from your sound clip. It sounds to me like you are mixing a drink instead of driving a car. My car is a 13' with 60k miles. No clunking.
If you fold down the rear seat is it more noticeable? I'd check the diff bushings. There is one on the nose of the diff too. I'd pull up a diagram of whatever you are inspecting and make sure all the components are there. They could have missed a spacer or sleeve that is causing excessive movement. |
#13 | |
#14 | |
not playing cards
| The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | kilohercas (03-12-2018), Teseo (03-12-2018) |
| The clutch is clunking | Ashley | Scion FR-S / Toyota 86 GT86 General Forum | 22 | 11-14-2021 11:30 PM |
| Suspension clunking (i think) | BRZ'13 | Issues | Warranty | Recalls / TSB | 15 | 09-21-2016 12:53 PM |
| clunking noise after LCA install | starron | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-17-2015 05:02 PM |
| Transmission Clunking (A/T) | Mr. J | Issues | Warranty | Recalls / TSB | 6 | 01-01-2013 08:11 PM |
| eibach sportlines clunking.. | frsguy707 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 16 | 10-24-2012 12:42 PM |
