Old 05-14-2015, 03:47 AM   #1
starron
Drives: FRS 10 Series
clunking noise after LCA install
so I've been having the ST coils on the car for about 6k miles with no issue. 2 weeks ago I finally got to put on the voodoo 13 LCA and the noise started to come. at first I thought it would be the end links problem like people had before. so today i removed the end links and sway bar out of the way and the noise still going strong when i put weight/pressure on the car's body.
please take a look at the video i put together in different angles and hope somebody can give suggestion or even a solution. I really have no idea where the noise is coming from....
starron is offline   Reply With Quote
Old 05-17-2015, 02:51 PM   #2
Backinthegame
Drives: 2015 FR-S
Check the jam nuts for your adjusters
Backinthegame is offline   Reply With Quote
Old 05-17-2015, 05:02 PM   #3
cnk
Drives: '13 DGM BRZ Limited
I had a similar noise when I was beta testing the Figs Mega Arms. What I did was to bounce the car up and down while placing my hands in different locations until I could isolate where the noise was coming from. For me, it was the pillowballs. One pillowball seemed to have a tiny bit of play in it that would result in a clicking noise just like your video.
I decided to just go with SPC arms and haven't had any noises since. The SPC arms use urethane mounts just like the stock arms so there is a little bit of compliance. Would have preferred to stick with the Figs arms, but the clicking was just driving me nuts while driving.
cnk is offline   Reply With Quote
Rear clunking noise when driving EvoXSwimmer Issues | Warranty | Recalls / TSB 4 07-24-2017 04:03 PM
kw v3 rear making clunking noise eera Suspension | Chassis | Brakes -- Sponsored by 949 Racing 4 12-17-2015 05:10 PM
Clunking noise after installing springs JACK 8URT0N Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 03-28-2015 04:37 PM
Whiteline LCA's light clunking noise FR-S Matt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 21 11-20-2014 10:22 AM
Clunking noise when on and off throttle and bumps DriftEightSix Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 04-24-2014 12:18 AM
