Old 10-21-2012, 12:48 AM   #1
frsguy707
frsguy707's Avatar
eibach sportlines clunking..
Hi my friend and I installed a set of eibachs sport line springs for the frs, it was good install (long but good) but just wanted to know if any of you sport line guys or gals out there are having any unusual clunking noise. I get an unusual clunking noise sometimes when I'm turning a corner or sometimes just driving straight road. Any feedback would be much appreciated thanks.
frsguy707 is offline   Reply With Quote
Old 10-21-2012, 01:25 AM   #2
mrha
#1819
mrha's Avatar
Drives: Lightning Red Subaru BRZ
Is the top screw torqued down?
mrha is offline   Reply With Quote
Old 10-21-2012, 01:38 AM   #3
chutrain
chutrain's Avatar
Drives: WRB BRZ
Top screw is always number one culprit to clunking. Always recheck the nuts and bolts that were removed for correctly torqued down.
If that isn't it, check the following:
Endlink nuts
Make sure springs seated properly
Make sure spring pads are seated properly
Three nuts at the top
Is it a definitive clunking? Or popping sound like coils are binding?
In the garage:
1988 BMW E30 M3
2003 Ducati ST4s ABS
2006 Subaru Legacy GT Spec B #444/500 (For Sale)
2013 Subaru BRZ WRB Limited - Acquired 9/15/12
chutrain is offline   Reply With Quote
Old 10-21-2012, 01:54 AM   #4
frsguy707
frsguy707's Avatar
eveyrthing was torqued down to specification, but apparently i did not recieve new bump stops with the springs would that be the cause of the clunking. also another thing when i got home to check everything out i noticed i have a blown strut leaking fluid on the rear passenger side.
Old 10-21-2012, 01:56 AM   #5
frsguy707
frsguy707's Avatar
the top screw was torqued down to sepecification.
Old 10-21-2012, 02:20 AM   #6
chutrain
chutrain's Avatar
Drives: WRB BRZ
Not sure how much the Sportlines lower, but I don't think it would be so low that they would be riding on bumpstops all the time. I believe there were cases where people complained about leaking struts on stock springs, and some immediately after aftermarket install. Put it all back to stock and have Scion replace under warranty.
In the garage:
1988 BMW E30 M3
Old 10-21-2012, 02:27 AM   #7
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
But the springs if purchased new and unopened, should have included 4 bump stops & 2 dust shields. If they did not contact the vendor you purchased from, and Eibach.
This was due to incorrect installation.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 10-21-2012, 02:29 AM   #8
86_ZN6
86_ZN6's Avatar
Drives: 86 ZN6
Not sure how much the Sportlines lower, but I don't think it would be so low that they would be riding on bumpstops all the time..
Distance from center of front wheel to fender
- FRONT
Stock springs: 14 7/16"
Eibach Sportline: 13 5/16" (1 1/4" drop)
Distance from center of front wheel to fender - REAR
Stock springs: 14 5/8"
Eibach Sportline: 13 5/16" (1 5/16" drop)
86_ZN6 is offline   Reply With Quote
Old 10-21-2012, 03:02 AM   #9
frsguy707
frsguy707's Avatar
well i purchased these from a vendor (not saying any names) they were used but not long at all maybe a thousand miles at the most. and we installed correctly every step.
Old 10-21-2012, 03:09 AM   #10
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Not saying you installed them incorrectly, but the guys who had leaking struts after installation with Sportlines.
But contact the vendor and see if they can give you/still have the bump stops from your kit. It sounds like that's your problem, to me at least.
Omar GC
Instagram: 2jzus
Old 10-21-2012, 03:25 AM   #11
frsguy707
frsguy707's Avatar
I contacted him tonight and he said he will be in the office @10 on Monday and he will see if he has the bump stops.
Old 10-22-2012, 01:18 AM   #12
miata
Drives: 2006 Miata 5 spd
Could it be riding on the stock bump stops? Even if there was a small travel distance, bottoming out hard on the long oem bump stops could have damaged the shock(s) and maybe that's why it is leaking. If the shocks are already damaged, I would not put them back on the car even with the shorter bump stops the vendor provides.
2006 Miata
miata is offline   Reply With Quote
Old 10-22-2012, 07:06 AM   #13
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Actually the previous cases were with prokit and some teins IIRC.
OP: Did you impact on the strut top nut?
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 10-22-2012, 07:09 AM   #14
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
I've had sportlines on for over 4,000 miles, including hours on Sebring which is extremely rough and did cause bumps top contact, my shocks are still fine.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
The clutch is clunking Ashley Scion FR-S / Toyota 86 GT86 General Forum 22 11-14-2021 10:30 PM
Eibach Sportlines Finally Available! PRO Import Tuners Brakes, Suspension, Chassis 1 08-22-2012 07:42 PM
Eibach Pro Kit - In stock! No Limit Motorsport Brakes, Suspension, Chassis 3 08-15-2012 05:21 PM
Eibach Pro Kit IslandImportPerformance Brakes, Suspension, Chassis 1 07-19-2012 11:33 AM
Eibach Pro Kit WithNolock Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 06-30-2012 11:50 AM
