Old 03-01-2018, 12:25 PM   #1
HeresMyMind
HeresMyMind's Avatar
Drives: 2013 WRB BRZ Limited
Alignment AFTER OEM Crash bolt install
Car:
2013 BRZ Limited
17x7 +42 RPF1s
215/45/17 RE71R tires
OEM Struts/Springs
Perrin Front 22mm Sway bar at soft.
OEM Crash bolts (front only)
This was the outcome. Thought I'd share.
-B
HeresMyMind is offline   Reply With Quote
Old 03-01-2018, 01:15 PM   #2
guybo
Huge E85 fan!
guybo's Avatar
Drives: 2016 Scion FRS
I used SPC crash bolts in the lower slot, & moved the bottom OEM crash bolts to the top. Ended up with -2.1 degrees of camber on otherwise stock suspension. If you get greedy for some more camber, try it. http://www.ft86club.com/forums/showthread.php?t=81407
Crash bolt install question cab33 DIY (Do-It-Yourself) Guides 2 07-09-2015 03:19 AM
Will OEM camber bolt install affect alignment B-R-Z Suspension | Chassis | Brakes -- Sponsored by 949 Racing 9 05-23-2014 11:30 PM
Alignment needed after front camber bolt install? ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 60 08-31-2013 12:13 AM
Crash bolt question ayau Tracking / Autocross / HPDE / Drifting 8 08-17-2012 01:22 PM
BRZ crash bolt same as Impreza lower strut bolt? xwd Tracking / Autocross / HPDE / Drifting 0 07-05-2012 12:19 PM
