Old 11-05-2017, 12:57 PM   #1
mleko
Drives: gt86
Reverse Cam Install
Hey
I have been watching allllll of the DIY and tutorials about Reverse Cam installation but i have still problem to understand what to do i connected all wires from the camera i got, but it still does not work
I have an Sinosmart +6v Camera and 16-pin to RCA harness for LCD conection
my main question is what should i do with the red wires that come with an RCA cable ? and what cable and where should i connect it to get power when in reverse mode
I hope you guys can help me i will add some photos over the stuff i got below
mleko is offline   Reply With Quote
Old 11-05-2017, 09:54 PM   #2
CraigVM
Drives: Car Collector
I think this is correct though someone who has hooked a 6V cam to their stock radio may need to confirm. Forgive my poor windows paint skills..... also make that "connect red wire on RCA extension cable to SUPPLY +6V from the head unit" shown in your top photo. I would use a multimeter and confirm that Supply wire produces 6V DC when vehicle is place into reverse.
CraigVM is offline   Reply With Quote
Old 11-11-2017, 03:44 AM   #3
DaveB.inVa
Drives: 2016 BRZ Premium
Remember you're using the red wire to provide power to the camera.
You need to get a wire from the harness that turns on to +12V when in reverse. I don't know what year your vehicle is but the +12V input will do two things.
1. It will trigger the head unit and make it turn to the reverse mode so the video input is displayed.
2. You will provide +6V from a 12V to 6V converter to power the camera.
I didn't go this route with my BRZ but I did on my Tacoma.
Attached is a link to a good 12V to 6V converter.
https://www.amazon.com/SMAKN-Convert...o+6v+converter
Once you have a reverse input at the head unit location, connect it with the input to the converter and to the reverse signal turn-on on the head unit.
Take the output from the 6V converter and connect it to the red wire going to the camera.
FYI, factory radios do all of this internally. They have an input that is 12V that goes to the head unit, there is an internal 12V to 6V converter and the head unit itself outputs 6V to the camera.
I don't know why aftermarket head units don't do this as well, but I've not seen one yet that does. It would sure make things more simple.
DaveB.inVa is offline   Reply With Quote
Old 11-11-2017, 10:58 AM   #4
sharpsicle
Certs You Dont Care About
sharpsicle's Avatar
Drives: 2013 Galaxy Blue BRZ
Aftermarket headunits are designed to work with 12v cameras, with the camera trigger wire being tapped into at the rear of the car rather than at the headunit. That's why.
sharpsicle is offline   Reply With Quote
Old 11-11-2017, 04:05 PM   #5
mleko
Drives: gt86
Thanks for all help boys camera looks perfect
Help With Reverse Camera Install tiz22 Electronics | Audio | NAV | Infotainment 28 09-08-2019 12:06 AM
Beat-Sonic reverse cam install help ! mike7792 Electronics | Audio | NAV | Infotainment 16 04-23-2017 03:23 AM
Need help with reverse lockout install StraightOuttaCanadaEh CANADA 6 04-18-2017 09:35 AM
late 2014 toyota gt 86 reverse camera install rsingh Electronics | Audio | NAV | Infotainment 1 10-21-2015 08:15 PM
Reverse Camera - install question Sutty AUSTRALIA 1 07-28-2012 08:40 AM
