CANADA Canada
Old 04-13-2017, 08:48 PM   #1
StraightOuttaCanadaEh
Wes
Need help with reverse lockout install
As the title states, I need help from someone that's done it before. If one of you doesn't mind being a good samaritan and lives in toronto, and has the right tools, I would really appreciate it. I really don't wanna go and buy a tool I'll only ever use once when I could borrow it instead. Anyone?
Old 04-14-2017, 12:21 AM   #2
CwpBrz
Now with 4 doors
CwpBrz's Avatar
Drives: 2018 WRX / 2013 Mazda 3
When i installed my raceseng reverse lockout all i did was go to the home depot to buy a drill bit that was 2.5mm. and used a hammer. Pretty straight forward actually. I could help you out if need be
CwpBrz is offline   Reply With Quote
Old 04-14-2017, 09:26 AM   #3
Wes
Alright I'll try that first. I thought I needed to buy some punch tool. Thanks!
Old 04-15-2017, 08:21 AM   #4
SLVRSRFR
Drives: 2013 BRZ 6MT, 2007 WRX Wagon 5MT
Punch tool is highly recommended.
I tried removing mine with a small allen key that fit in the hole. After almost an hour of hitting it gently with a hammer, and fighting with it, I ended up breaking the stock plastic reverse lock-out. Cracked a huge piece off of it. Luckily I had a mechanic friend that had the exact size of punch that I needed, (3mm if I recall correctly), so I was able to finish the install.
Once I had the correct tool, it took me all of 5 minutes to remove the OEM one and put the new one on, which is why it might be in your best interest to try to get a punch instead if possible.
Good luck!
@bpennerz
SLVRSRFR is offline   Reply With Quote
Old 04-15-2017, 08:50 AM   #5
Wes
Good luck!
Thanks! CwpBrz helped me out, bless him. He had a drill bit only slightly thicker than the one I was using and it came out in about 10-15 seconds! So yeah, the right thickness is important
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post:
SLVRSRFR (04-15-2017)
Old 04-18-2017, 12:32 AM   #6
FRS2017
Enthusiast 86
FRS2017's Avatar
Drives: Toyota 86 GT
So you can re-use the pin with the new reverse lockout I presume, I just got a $10 Aluminium reverse lockout from eBay and will try it when I get it, I must remember to use the correct punch key.
FRS2017 is offline   Reply With Quote
Old 04-18-2017, 09:35 AM   #7
Wes
Correct. Just make sure you hammer it back in all the way or it'll rattle
Red Reverse Lockout dieseldan444 Interior Parts (Incl. Lighting) 4 09-28-2016 12:47 AM
WTB: OEM Reverse Lockout Ethereal05 Want-To-Buy Requests 2 07-18-2016 04:01 PM
wtb oem reverse lockout Vincenttam Want-To-Buy Requests 0 02-09-2015 05:41 AM
Reverse lockout? MrMarinakos Cosmetic Modification (Interior/Exterior/Lighting) 0 04-28-2014 08:47 PM
