Old 09-22-2014, 09:53 PM   #1
mike7792
mike7792's Avatar
Drives: 2014 Scion FR-S
Beat-Sonic reverse cam install help !
So I have a 2014 FR-S with the oem touchscreen unit without navi
I bought the Beatsonic reverse cam with the BCUS3 adapter
I followed the instructions for the 2013 FRS DIY
The camera will only show up on my Headunit if I ignition ON/start up car with the car in Reverse gear.
If I start the car or ignition on with the car in neutral, the camera does not work and will not show up on the headunit
There is power in all the connections.
any help would be appreciated
mike7792 is offline   Reply With Quote
Old 09-22-2014, 10:46 PM   #2
aznatama
aznatama's Avatar
Drives: 2014 BRZ MT (Sold); 2006 V70R
That is what a reverse camera does, it turns on when you're in reverse so you see where you're going when you back up.
What did you expect it to do?
'14 BRZ LTD MT DGM
aznatama is offline   Reply With Quote
Old 09-22-2014, 10:51 PM   #3
mike7792
mike7792's Avatar
That's not what mine is doing.
I said, it will only work if I start the car with reverse gear engaged. (it will stay working until I shut the car off)
If I start the car in neutral it does not work at all. It will not work at all unless I do the above method once.
Old 09-22-2014, 10:57 PM   #4
aznatama
aznatama's Avatar
That's weird then... Make sure you have the correct power lead tapped and no wires are crossed. Sounds like the HU is not picking up the reverse signal for some reason, and thus not switching to the camera. Could be a ground issue somewhere.
'14 BRZ LTD MT DGM
Old 09-22-2014, 11:09 PM   #5
Bigbadvoodooguru
Drives: 2014 asphalt FRS
the head unit in our cars requires the camera to have power immediately after the vehicle is turned on. The head unit does a check over the video-in signal immediately on start up. If there is no signal (camera not powered on), then the head unit disables reverse camera until the next time the car power is cycled.
Thats why it works if you start in reverse, you are powering the camera immediately on start up.
Bigbadvoodooguru is offline   Reply With Quote
Old 09-22-2014, 11:11 PM   #6
aznatama
aznatama's Avatar
In that case... Just tap an always on power source.
'14 BRZ LTD MT DGM
Old 09-22-2014, 11:17 PM   #7
mike7792
mike7792's Avatar
Right now the power source is tap from the accessory power. The same power source for the radio. Does that work?
it is always on once the car is started.
Old 09-22-2014, 11:19 PM   #8
aznatama
aznatama's Avatar
Then the power doesn't appear to be the problem... I don't know. My brz doesn't have this problem.... XD
'14 BRZ LTD MT DGM
Old 09-22-2014, 11:23 PM   #9
mike7792
mike7792's Avatar
I have a feeling this BCUS3 harness may be faulty? i have no idea but Beat-Sonic has yet to get back to me
Old 09-23-2014, 08:58 AM   #10
aznatama
aznatama's Avatar
Not sure what the harness is for. In my install, the harness is only for turning the video pinout into an RCA plug for the camera. Since you're tapping a power source that turns on immediately, you should have no problem according to the other poster.
Are you sure the power is 5v and not 12v? I made that mistake at first. Have you used a multimeter to test your power to make sure it actually does come on right when you turn on the car?
'14 BRZ LTD MT DGM
Old 09-23-2014, 04:38 PM   #11
phobos512
phobos512's Avatar
Drives: 2014 FR-S 6MT Whiteout
Are you sure accessory and radio are the same power? Whatever you have it plugged into isn't obviously turning on at the right time or else it'd work. If you check the impedance on the harness you can rule it out real quick.
Matt | '14 FR-S 6MT Whiteout | '13 Sonata Hybrid | '11 CBR1000RR
phobos512 is offline   Reply With Quote
Old 09-23-2014, 10:49 PM   #12
mike7792
mike7792's Avatar
Thanks for the input guys.
I'll give it a go on the weekend when I have more time to work on it.
Old 09-25-2014, 04:04 PM   #13
Beat-Sonic
Beat-Sonic's Avatar
Drives: Toyota and Lexus
Hi Mike,
Please keep us updated with the progress based on the troubleshooting provided from our engineer.
Please let us know if you are still encountering any issues.
Thanks,
Beat-Sonic is offline   Reply With Quote
Old 09-25-2014, 04:20 PM   #14
mike7792
mike7792's Avatar
Originally Posted by Beat-Sonic View Post
Hi Mike,
Thanks,
Thanks, I will keep you informed. I won't be able to work on the car until Sunday at the earliest.
ps... Now my daytime running lights stopped working... I wonder what my friend did on the installation?! gahhh
DIY Beat-Sonic Backup Cam Install (FRS) Techfl3x DIY (Do-It-Yourself) Guides 26 07-22-2015 02:30 PM
Beat-Sonic FR-S Photos Beat-Sonic FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 46 08-29-2013 10:35 AM
Beat-sonic JDM shark fin antenna install. jadewbj Cosmetic Modification (Interior/Exterior/Lighting) 23 05-23-2013 01:12 AM
