Old 10-18-2015, 09:55 PM   #1
rsingh
Drives: gt 86
late 2014 toyota gt 86 reverse camera install
I have the entry level late 2014 toyota gt 86 the one that comes with a non touch screen and I was wondering does this car have a reverse wire that i can get a harness to connect a reverse cam or do I need to splice into the reverse sensor cable in the kick panel? I know the gts model has the reverse cable where you can just get a harness
rsingh is offline   Reply With Quote
Old 10-21-2015, 08:15 PM   #2
RustySocket
Slow Learner
RustySocket's Avatar
Drives: 15 Halo FRS
If you pull your headunit out and look at the 28pin connector, if it has a wire in position 2 it has the reverse trigger installed, if it is blank then you will have to run the wire yourself.
My 2015 Scion did not have the wire and I had to run it myself. I know some of the BRZ's have the trigger wire, I don't know about the GT86 and am making the assumption that it has the same headunit as the scion.
There are ton's of threads here that will help you figure it out if you search a little bit.
@SVXdc has a website with lots of good wiring info and he can probably give you a more definitive answer.
http://ae64.com/
RustySocket is offline   Reply With Quote
Help With Reverse Camera Install tiz22 Electronics | Audio | NAV | Infotainment 28 09-08-2019 12:06 AM
FYI - it's possible to add a reverse camera for $20. SloS13 Electronics | Audio | NAV | Infotainment 25 09-09-2013 10:03 PM
Reverse Camera FT86_Zero Scion FR-S / Toyota 86 GT86 General Forum 26 08-05-2012 08:05 PM
Reverse Camera - install question Sutty AUSTRALIA 1 07-28-2012 08:40 AM
Reverse camera? dorkymork BRZ First-Gen (2012+) — General Topics 28 05-21-2012 10:21 AM
