Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > AUSTRALIA
AUSTRALIA Australia and New Zealand
Old 07-28-2012, 04:08 AM   #1
Sutty
Sutty's Avatar
Drives: Sonic Blue 86 GTS 6AT
Reverse Camera - install question
One of the things that I am wanting to do when my 86 arrives is fit a reverse camera.
Can anyone with knowledge of these please answer the following:
Is the wiring harness already installed in the GTS, i.e. I'll only have to plug the camera in one end and then make sure the harness is plugged in to the head unit at the other end. The reason I ask this is that the camera that I believe will fit (Eclipse BEC-108 http://www.woofersetc.com/p-8263-bec...ead-units.aspx) comes with a harness. Not worried about having to run wires etc, but then again want to know what I'm getting into.
Can anyone confirm that the previoiusly linked camera is the right one that will work with the GTS head unit, I really want a plug and play unit.
Do you need to wire something to the gear lever in order for the camera to acitivate or does the existing wiring already accomodate that.
Does anyone know of an aussie retailer that sells Eclipse cameras.
Has anyone already done this and can tell me of any problems or issues.
I have had a look at a few of the forums here already that deal with reversing cameras but can't see answers to my questions.
Thanks
Sutty is offline   Reply With Quote
Old 07-28-2012, 08:40 AM   #2
Psoo2010
Drives: Toyota 86
It's the same camera and harness for all current f-ten Toyota head units (with the 6inch display). The one you listed is the same as the one from dealers, just that the different toyota part numbers give you different instruction manuals specific to models.
Running the harness from the HU to the back is the easy bit. The hardest bit is to cut a section near the rear number plate light for the camera bracket.
From memory no other wiring is required other than the factory harness.
Psoo2010 is offline   Reply With Quote
"Genuine" reverse camera manboobs AUSTRALIA 35 09-13-2013 08:35 AM
Water in reverse lights roddy Scion FR-S / Toyota 86 GT86 General Forum 30 05-09-2013 09:18 AM
Radio Signal Issue When shifting into Reverse ruskymx Scion FR-S / Toyota 86 GT86 General Forum 13 01-22-2013 09:05 PM
Reverse Camera FT86_Zero Scion FR-S / Toyota 86 GT86 General Forum 26 08-05-2012 08:05 PM
Reverse camera? dorkymork BRZ First-Gen (2012+) — General Topics 28 05-21-2012 10:21 AM
