Old 10-23-2017, 09:44 PM   #1
ghostzfh
Drives: 2016 Scion FRS Halo
How is it possible to lose coolant, if the coolant system in a car is a closed loop,
I have confusion as to why people need to top off their coolants from time to time. How is that a phenomenon if the cooling system is supposed to be a closed loop? I understand that if there were leaks, then losing coolant is apparent, but if there are no leaks, how is it possible? I thought that if it was a closed loop, you should not lose a single drop of coolant.
Edit #1: The title got cut off for some reason, but the entire title is: How is it possible to lose coolant, if the coolant system in a car is a closed loop, and there are no leaks?
ghostzfh is offline   Reply With Quote
Old 10-23-2017, 09:48 PM   #2
ermax
ermax's Avatar
It leaks or burns. This is your second coolant thread. Are you loosing coolant? If so, how much and how often? I asked this in the other thread but you didn’t answer.
The Following 2 Users Say Thank You to ermax For This Useful Post:
DarkPira7e (09-10-2020), soundman98 (09-11-2020)
Old 10-23-2017, 10:09 PM   #3
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Your statement can only be accurate if you assume it is a closed loop.
In reality, it is not a closed loop.
You can seep moisture via any of the gaskets, bad seal, head gaskets. You also have a radiator cap that vents excess pressure if the temps are too high, which means you have coolant that has escaped a "closed loop"
-alex
The Following 4 Users Say Thank You to mav1178 For This Useful Post:
Brzerker (10-23-2017), DarkPira7e (09-10-2020), ghostzfh (10-24-2017), Opie (10-24-2017)
Old 10-24-2017, 12:26 AM   #4
ghostzfh
@ermax Did you read my question in it's entirety? "...if there are no leaks, how is it possible?" Also, See my latest post on the previous thread.
@mav1178 Those things you mentioned, "gaskets, bad seal, head gaskets, etc." are all about problems associated to abnormal damage? I'm wondering about if the coolant system is designed without any issues. Is the coolant system designed to be closed entirely, is what I'm asking, and why there are any losses if there are no leaks.
Old 10-24-2017, 12:55 AM   #5
ermax
ermax's Avatar
No it isn’t closed entirely. The cap is designed to put pressure on the system which raises the boiling point. But it is also designed to bleed off if the temp goes too high. Other than that it’s closed.
I’ve never owned a car that didn’t consume a little. You still haven’t given a clear answer on how much and how often you are putting coolant in.
Edit: Mav already addressed this. Sorry.
Old 10-24-2017, 02:54 PM   #6
mav1178
mav1178's Avatar
You can lose coolant if you boil over via the radiator cap, but not all of the boiled over liquids make it back into the radiator after the engine cools down.
Over time this ends up in the overflow tank.
90% of the time a car overheats because the radiator cap has gone bad.
The Following User Says Thank You to mav1178 For This Useful Post:
Old 10-24-2017, 04:24 PM   #7
Sideways
BRZZZZZ
Sideways's Avatar
Drives: 2013 BRZ Whiteout
To answer your question, if the coolant system is design and is really made to be closed entirely (and I mean perfectly sealed), you will not have any coolant loss.
But as others have said, no modern car have a sealed closed coolant system. The twins have coolant loop that allows venting to prevent pressure buildup and for coolant to flow in case it boils. Coolant evaporates when it comes in contact with engine block and that evaporated coolants builds pressure. Now the pressure will travel from high pressure to low pressure point (outside the coolant loop) as there is no venturi effect happening and hence the air will try and find its way out. And this air pressure sometimes also pushes coolant into the overflow tank.
Sideways is offline   Reply With Quote
The Following User Says Thank You to Sideways For This Useful Post:
Old 10-24-2017, 04:55 PM   #8
steve99
overflow tank has vent hole in it. Coolant evaporates out vent hole
The Following 4 Users Say Thank You to steve99 For This Useful Post:
Capt Spaulding (10-24-2017), ghostzfh (10-24-2017), terry12t (09-10-2020), zc06_kisstherain (10-24-2017)
Old 09-10-2020, 10:18 PM   #9
terry12t
Drives: BRZ 2017 type S
thanks bro, it's bothered me for months till i foud this vent hole.
terry12t is offline   Reply With Quote
Old 09-11-2020, 04:15 PM   #10
pallen
pallen's Avatar
Drives: 2017 Toyota 86
Yep - its not really a sealed system. The coolant is somewhat close to boiling, so it wants to evaporate - there are a few opportunities for evaporation and slight leakage over time. You shouldn't be losing much coolant though. It should be a very minimal loss.
pallen is offline   Reply With Quote
Old 09-11-2020, 05:02 PM   #11
gg1978
Drives: 2016 Subaru BRZ Limited Ice Silver
As others have said, the overflow tank isn't 100% sealed for a reason, and on the Twins, is about a foot away from a quite toasty catalytic converter, which would tend to encourage the water to evaporate out of the coolant. Most cars don't have the overflow tank so close to the hot exhaust components, so they typically do better in this regard.
gg1978 is offline   Reply With Quote
The Following User Says Thank You to gg1978 For This Useful Post:
jeepmor (01-16-2021)
Old 09-11-2020, 06:56 PM   #12
ls1ac
ls1ac's Avatar
Steve99 is right on. The coolant expands and flows into the overflow tank. It is hot and evaporates (at a slow rate),
I too am still waiting for an answer to how much how often is lost from OP.
The Following User Says Thank You to ls1ac For This Useful Post:
Old 09-11-2020, 08:56 PM   #13
DarkPira7e
Rust bucket enthusiast
DarkPira7e's Avatar
Wait. You don't buy a gallon of coolant with every 5 quarts of oil and a filter?
Old 09-11-2020, 09:22 PM   #14
86MLR
86MLR's Avatar
Food for though
https://motocrossactionmag.com/ten-t...rless-coolant/
http://www.ft86club.com/forums/showthread.php?t=133311
I'm only here for the biscuits
coolant, coolant reservoir
VIDEO - Install guide for OEM style coolant loop Oil cooler. The Sentinel DIY (Do-It-Yourself) Guides 44 10-15-2018 09:42 AM
Coolant loss - Void Warranty/ Edit: coolant flush question BRZach Engine, Exhaust, Transmission 15 01-02-2016 09:21 PM
Real-time Oil temperature Analysis - Pre/Post Coolant Loop Oil Cooler Install The Sentinel Engine, Exhaust, Transmission 92 03-09-2015 06:20 PM
Subaru OEM Coolant System Additive JDKane527 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 1 05-27-2014 02:24 PM
Engine Coolant system sw20kosh Engine, Exhaust, Transmission 1 04-01-2014 01:26 PM
