Old 05-27-2014, 12:26 PM   #1
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
Subaru OEM Coolant System Additive
I have a small coolant leak from my radiator. I found this Subaru OEM Coolant Additive that has been recommended for leaks in older Subaru vehicles. Would it be fine to run in the FA20?
[ame="http://www.amazon.com/Genuine-SOA635071-Engine-Coolant-Additive/dp/B007WR8DD0/ref=pd_sim_auto_5?ie=UTF8&refRID=081G75D7ADKQK1GSR 3V0"]Amazon.com: Genuine SOA635071 Engine Coolant Additive: Automotive[/ame]
Thanks in advance.
JDKane527 is offline   Reply With Quote
Old 05-27-2014, 01:24 PM   #2
tobin
tobin's Avatar
Drives: '13 BRZ
That was used in the old 2.5 liter cars to help prevent head gasket failure. I ran that with no issues in my old Legacy GT past 150,000 miles on the original gaskets. It's not a stop leak and will most likely not fix your problem. I also personally wouldn't use it in my FA20 as it wasn't designed for this engine. What caused the leak? Can you bring it back to the dealer as a warranty issue?
tobin is offline   Reply With Quote
Old Homelink System-Shame on Subaru poudre BRZ First-Gen (2012+) — General Topics 30 07-06-2014 12:21 PM
Turbo coolant lines GTX2867. Can I use the throttle body coolant lines? mike the snake Forced Induction 8 04-01-2014 05:56 PM
Engine Coolant system sw20kosh Engine, Exhaust, Transmission 1 04-01-2014 12:26 PM
FS: Stock exhaust system Subaru BRZ Limited djleepanda Engine, Exhaust, Bolt-Ons 0 08-16-2013 04:59 AM
FRS 86 BRZ ECU to follow Subaru system? vin0410 Engine, Exhaust, Transmission 2 04-23-2012 02:15 PM
