Old 04-01-2014, 12:22 PM   #1
sw20kosh
Drives: 2013 Black FR-S
Engine Coolant system
At cruising speeds my coolant temps will stay at 190-192.
Once I hit traffic it will creep up to 230ish within a minute or two and then it will suddenly drop down to 190 again when the fans come on. Then it will creep back up to 230 etc...
I have the robispec giant radiator. Does this sound like normal operation?
Old 04-01-2014, 12:26 PM   #2
JDKane527
JDKane527's Avatar
Drives: Asphalt Scion FR-S
That's not normal. Could be low on water, or leaking at the drain plug. Inspect the radiator cap to ensure its clean. I used some GM coolant tablets that CBR recommended I try for any small leaks, and it clogged up the radiator cap. Fluid could flow out of the system, but not back in. I had to clean it out with distilled water and replaced coolant fluid.
JDKane527 is offline   Reply With Quote
Checking and Changing BRZ/FR-S Engine Coolant GrimmSpeed DIY (Do-It-Yourself) Guides 39 05-29-2023 08:15 AM
Coolant low (when engine is hot) Ben_G Engine, Exhaust, Transmission 4 12-09-2013 08:31 AM
Green engine coolant used quickly? Tylub Issues | Warranty | Recalls / TSB 19 06-19-2013 01:15 PM
Engine Coolant? L3P47 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 4 04-13-2013 11:33 PM
Normal Engine Coolant Temps? Dezoris Engine, Exhaust, Transmission 1 04-05-2013 03:17 PM
